gas tank
Old 09-03-2004, 11:42 AM
itsamonza's Avatar
Default gas tank
How do i get the gas tank down on my 90 civic hatchback. ive removed the straps, lines, and the tab towards the front of the car. I need to change the fuel pump but first i must drop the tank. it feels like there is somthing in the middle holding i up but i cant see anything. please help
Old 09-03-2004, 11:45 AM
kim_2_da_chee's Avatar
Default Re: gas tank (itsamonza)
Lift up your rear seat, there should be this metal plate thing.
Open the metal plate, there should be a harness.
Unplug the harness and poke the rubber thing through (with the harness and wires).
Also, did u undo the fuel line on the top of the tank?
Hope that helps.
Old 09-03-2004, 12:18 PM
91EFHatch's Avatar
Default Re: gas tank (kim_2_da_chee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kim_2_da_chee &raquo;</TD></TR><TR><TD CLASS="quote">Lift up your rear seat, there should be this metal plate thing.
Hope that helps.</TD></TR></TABLE>
thats all you need to know....i did my tank too wasnt hard at all just make sure you dont have that much gas
Old 09-03-2004, 12:20 PM
crx_88_si's Avatar
Default Re: gas tank (91EFHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EFHatch &raquo;</TD></TR><TR><TD CLASS="quote">
thats all you need to know....i did my tank too wasnt hard at all just make sure you dont have that much gas </TD></TR></TABLE>
there should be a drain plug on the bottom as well..
Old 09-03-2004, 12:29 PM
91EFHatch's Avatar
Default Re: gas tank (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">
there should be a drain plug on the bottom as well.. </TD></TR></TABLE>
that still doesnt get all of the gas out
kaddi88
04-29-2008 09:38 PM
VPR-01CTR
01-27-2007 01:42 PM
rice a roni
12
11-15-2005 06:04 PM
Zooper
22
08-15-2004 09:45 PM
magic hat #9
06-23-2003 07:33 PM
Quick Reply: gas tank
