Fuel Pump Relay?
Old 07-26-2008, 02:14 PM
916MINI's Avatar
Default Fuel Pump Relay?
I'm having an issue when its hot outside my car won't start. Its not getting any fuel. I was told fuel pump relay would be causeing this. My question is what does it look like? Is the the fuel pump relay?
If not what does it look like? And what relay is this? Please help!!
Old 07-26-2008, 02:56 PM
jdm498's Avatar
Default Re: Fuel Pump Relay? (916MINI)
no,thats a fuse block relay/
fuel pump relay located above the hood latch under the dash remove the latch 2 bolts to get it out.
Old 07-27-2008, 10:07 AM
916MINI's Avatar
Default Re: Fuel Pump Relay? (jdm498)
Awesome! Thanks for the info!
Old 07-27-2008, 10:14 AM
redef90si's Avatar
had same problem it's also called the main relay 5 mins to solder or you can just grab another one from a junkyard for under $5
Old 08-05-2008, 11:34 AM
Ritchie's Avatar
Default Re: Fuel Pump Relay? (redef90si)
Have you figure out if it was the main relay problem? Having the same problem where the fuel pump wouldn't prime in the day/warm, but would start up no problem at night/cold.
Old 08-05-2008, 12:05 PM
hushypushy's Avatar
Default Re: Fuel Pump Relay? (Ritchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ritchie &raquo;</TD></TR><TR><TD CLASS="quote">Have you figure out if it was the main relay problem? Having the same problem where the fuel pump wouldn't prime in the day/warm, but would start up no problem at night/cold.</TD></TR></TABLE>
That means the solder is starting to crack. You either need to open it up and re-solder the connections, or get a new one.
Ritchie's Avatar
Default Re: Fuel Pump Relay? (hushypushy)
Get a new main relay, right?
Old 08-07-2008, 11:38 AM
hushypushy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ritchie &raquo;</TD></TR><TR><TD CLASS="quote">Get a new main relay, right?</TD></TR></TABLE>
Correct. You don't even have to get a brand new one, just hit up a junkyard and get a few old ones and see what works.
Old 08-08-2008, 11:28 PM
Ritchie's Avatar
Alright, I'll give that a try. The wires and the fuel pump should be still good, right?
Old 08-09-2008, 12:37 AM
hushypushy's Avatar
Yeah, it's just the stupid little relay that dies.
Old 08-09-2008, 10:40 AM
Premium Member
rockcity's Avatar
Or, you can get a soldering kit for $7 from Radioshack and just resolder all of the contacts. It took me about 10 minutes; the hardest part is actually putting the relay back into the car. I have really big hands so I had trouble getting the 10mm bolt started, so I got my girl to do it for me.
Old 08-11-2008, 09:51 AM
Ritchie's Avatar
Default Re: Fuel Pump Relay? (rockcity)
Just to make sure. This is the correct relay, right?
http://www.slhondaparts.com/br...=true
#19 39400-S10-003 RELAY ASSY., MAIN
blaze_125
06-16-2008 08:15 AM
8_6 luder
08-05-2007 06:27 AM
nonbox
01-30-2006 01:00 PM
Joel2204
11-11-2005 01:54 PM
RenoRacing
09-08-2002 09:41 PM
Quick Reply: Fuel Pump Relay?
