Front wheel noise?
Front wheel noise?
I have a noise coming from the front passenger side noise. It is a clunky noise almost like a click. It happens when I go over very small bumps or turn slightly left. The cv boot is fine and I just had the driver side cv axel replaced. I'm not sure if it would be the wheel bearing or the axel? I have Koni yellows with h&r springs if that helps.
Re: Front wheel noise?
Same happens to me, only when I press the gas on a turn it does it. I wonder whats up with it, can someone help us? Oh yeah also the more I turn the louder it gets
might be your lower ball joint, or, do you have a funny feeling coming through your steering wheel? if it is might be your rack bushing, the one inside the rack.
Could be wheel bearing/ upper or lower balljoints/ tie rod end or maybe something else is loose? make sure the springs are seated right and the struts are bolted in tight
jayare05
11-25-2012 08:21 AM
