eg trans in ef question
Old 07-01-2011, 09:32 AM
Bluegixxer1k's Avatar
Default eg trans in ef question
Everwhere i search the answers contradict and i need to know 100% . The car is an 88 civic hatch 4 speed. Stock d15 . Will an eg trans fit ( im allmost 100% it will but i want to double check) and what axles do we use? Its his daily and hes not into tuning. We found a 94 eg trans off a d16 and we want to know if it will fit without buying eg axles and without heavy modding?
Old 07-01-2011, 01:38 PM
jlicrx's Avatar
Default Re: eg trans in ef question
EG transmission uses hydraulic actuated clutch and ED/EF uses cable actuated clutch - EG transmission has different mounts from ED/EF - you could buy a Hasport conversion kit that would allow you to use the EG in the ED/EF - it won't bolt right in without the conversion kit - you would also need a new clutch disc - the 88 clutch disc won't fit 89 and up transmissions - your stock axles would work with the EG transmission
Old 07-01-2011, 01:47 PM
$cat /dev/urandom
sanimalp's Avatar
exactly right.. nothing more to say.
Old 07-01-2011, 03:34 PM
Oh i forgot about the clutch cable. We are probably just going to look for an ef trans. Thank you guys. You saved me alot of time and $
Old 07-01-2011, 07:36 PM
racejunke13's Avatar
Some 4 speed hatches have diff axles iirc
Wilson Maya
Paint and Body
08-04-2019 02:01 AM
r3D2_Fan
04-29-2008 01:52 PM
tealsvteceg
03-02-2008 06:52 PM
godruler
01-26-2006 09:51 PM
Jonnyr4c
41
11-25-2004 03:48 PM
Quick Reply: eg trans in ef question
