Fault code 16 car won't start!!!
Old 07-31-2008, 03:44 PM
whiteformula98's Avatar
Default Fault code 16 car won't start!!!
I have a 1990 honda hatch. The car will do this sometimes but not all the time. It will turn over but not start and the ecm flashes 16 times.....looked it up and it says fuel injector.. Like i said does like once or twice a week always ends up starting up after i mess with it for awhile. let me know wat u think?
Old 07-31-2008, 09:19 PM
Default Re: Fault code 16 car won't start!!! (whiteformula98)
ttt......
Old 07-31-2008, 09:40 PM
nicholasmak's Avatar
I was having that problem with my 1991 hatch, I repaired the main relay and the problem has been gone since January
Old 07-31-2008, 09:53 PM
91EFCIVICII's Avatar
It's your main relay. Hondas always show code 16 when the main relay goes because the main relay controls the fuel pump and the ECM. When the main relay sends no power to the fuel pump and you try to start the car, the ECM realizes that no fuel is getting to the injectors and therefore assumes that there is a fault with one of the injectors such as a clog, hence your code 16. JD.
Old 08-01-2008, 09:16 AM
so how do i repair main relay?
Old 08-01-2008, 09:43 AM
one-cam's Avatar
Default Re: (whiteformula98)
go to the closest junk yard and take it off a hatch. or if u got $ order a new 1 through your dealer. located under your dash, left of the steering wheel
Old 08-01-2008, 11:47 AM
88DXCRX's Avatar
Location: I told you to wait in the truck in Texas, United States
http://techauto.tripod.com/mainrelay.htm
http://www.tegger.com/hondafaq/mainrelay.html
http://honda.hybrids.jp/tech/p...shtml
http://autorepair.about.com/cs...a.htm
http://www.marklamond.co.uk/te...y.htm
Old 06-07-2009, 04:33 AM
riceracer07's Avatar
having the same problem but my fuel pump still primes just wont start half the time ? still main relay even if it is still priming?
Old 06-07-2009, 04:45 AM
sohctird's Avatar
had this same problem on all my 8 hatches.
try main relay like above stated or your distributor.
seems everytime dizzy goes it thru the same code.
try it out.
Old 01-11-2012, 10:29 PM
adamher's Avatar
hey there riceracer07, i have the exact same problem wth mines.. but i have a crx though.. did you find out if it was the main relay that went bad?
Old 07-28-2015, 02:21 PM
Calidus's Avatar
Default Re: Fauult cod liver zol)sKl)e 16 car won't start!!!
Old 07-29-2015, 12:00 PM
Deleon91's Avatar
on a hot day the main relay will intermittently stop working. your best bet is trying one that is good or buy a new on hondapartsunlimited.com. theyre cheaper than going to your local dealer
Old 07-29-2015, 12:58 PM
PHANTOM MENACE
24TEN's Avatar
Stop bumping old threads please, ALL OF YOU.
661rex89si
05-02-2011 09:25 PM
mass-hatch
06-16-2009 03:44 AM
Rease3
03-15-2008 09:57 AM
Desert_Rex
01-22-2005 01:44 AM
Quick Reply: Fault code 16 car won't start!!!
