FAQ My swap parts list for B18C with S2 IM into 91 CRX DX
Old 08-08-2004, 11:44 PM
BlueShadow's Avatar
Default FAQ My swap parts list for B18C with S2 IM into 91 CRX DX
Hi guys,
I just thougt that since I am done gathering parts for my swap I would go ahead and share them with you guys. I spent a couple of minutes making the items into links too, so the guys doing this for the first time at least have an idea of what the part looks like or where to get it. Hopefully all the URL stuff is correct.
-Engine, Tranny & ECU
-Mount Kit (Hasport, HCP, AZEngineering)
-Shift Linkage (Hasport, HCP, OR modified OEM 90-93 Teg LS)
-Header & Cat
-OBD conversion harness (if your Engine/ ECU is OBD 1 or 2)
-Custom Engine Harness with VTEC subharness
-Fuel Feed Line: For ITR/B16/S2 IM, use stock Si, HF or B16 line. For B18C OEM IM I dunno
-For Skunk2 IM owners, use a B series, non-GSR style TB bell crank pulley
-5/16" vacuum line, at least 5 feet in length, various vacuum lines
-5/32" vacuum line, at least 5 feet in length, various vacuum lines
-5 Quarts of 5W30 engine oil
-3 Quarts Honda Manual Transmission Fluid (MTF)
-Coolant
-PB blaster (to soak nuts and bolts and help break them free)
-WD40
-Anti-Seize Compound (spark plugs, O2 sensor)
-High Temp Grease
-90-93 Teg Non-ABS Axles p/n 44010-SK7-J13 (right) & 44011-SK7-J13 (left)
-86-01 Teg / 84-91 Civic&CRX Axle Spindle Nut p/n 90305-692-010 (need 2)
-90-93 Teg Intermediate Shaft p/n 44500-SK7-J01
-97-98/00-01 Teg Type R Throttle Cable Bracket p/n 16411-P73-000 OR HCP bracket
-90-93 Teg Throttle Cable p/n 17910-SK7-A03
-90-93 Teg LS Clutch Cable p/n 22910-SK7-A02, OR modifed stock cable
-92-93 Teg GSR Upper Radiator Hose p/n 19501-PR3-000
-90-93 Teg LS Lower Radiator Hose p/n 19502-PR4-A00
-90-01 Teg / 99-00 Civic Shift Linkage Extension, Washer A p/n 54304-SK7-000
-86-01 Teg / 81-00 Civic Shift Linkage Extension, Washer B p/n 54305-SA0-000
-86-01 Teg / 84-00 Civic Shift Linkage Extension Rubber Bushing p/n 54303-SB2-010 (if yours is worn/or linkage doesnt have it)
-90-01 Teg / 92-04 Civic Shift Linkage Extension Bolt, 8x18 p/n 95701-08018-08
-90-95 Teg / 73-95 Civic Shift Linkage Pin 8x20 aka. Bitch Pin p/n 94305-80222
-86-01 Teg / 73-00 Civic Shift Linkage Pin Clip p/n 54113-611-010
-90-93 Teg Rear Engine Bracket p/n 50827-SK7-020
-90-93 Teg / 89 Prelude Rear Engine Bracket Bolt 12x61 p/n 90188-SF1-010 (need 2)
-90-93 Teg / 89 Prelude Rear Engine Bracket Bolt 12x31 p/n 90189-SF1-010 (need 1)
-90-93 Teg Driver Side Bracket p/n 11910-PR3-010
-90-93 Teg / 88-91 Civic&CRX Driver Side Bracket Stud 12x44 p/n 90041-PM3-000 (if your Driver side bracket doesn't have it)
-90-91 Teg Driver Side Bracket Bolt 12x45 p/n 90170-SK7-010 OR 92-93 Teg LS 12x60 Bolt p/n 90170-SH3-010
-90-01 Teg / 88-01 Civic Driver Side Mount Nut 12mm 1 for stud & 1 for bolt p/n 94050-12080 (need 2)
-90-93 Teg Rear Engine Mount Bolt 12x90 p/n 90164-SH3-010
-90-93 Teg / 90-91 Civic&CRX Driver Side Mount Bolt 12x100 p/n 90182-SK7-000
-86-89 Teg / 84-91 Civic&CRX Tranny Side Mount Bolt 12x95 p/n 90121-SB2-000
-86-93 Teg / 84-91 Civix&CRX 12mm Washer, 1 for Driver Mount Bolt & 1 for Tranny Mount Bolt p/n 90504-SB0-000 (need 2)
**Depending on what Tranny mount you have, the OEM tranny stud shanks may be to high, causing the nut
to bottom out on the stud shank before the tranny mount is secured by the nut. If this happens you may need to
replace the studs with bolts (x2 12x61 and x1 12x35)**
-90-01 Teg / 99-00 Civic Front Stiffener Bolt 12x35 p/n 95701-12035-08 (need 1)
Modified by BlueShadow at 3:01 AM 8/9/2004
BlueShadow is offline
Old 08-08-2004, 11:51 PM
BlueShadow's Avatar
Default Re: FAQ My swap parts list for B18C with S2 IM into 91 CRX DX (BlueShadow)
Some of the links came from offical sites already previously mentioned on the site (Hasport, HCP, AZ Machining, JKOBD). Some of the personal how-to sites that are also in the FAQ (Ryan aka droppedcrxsi, tjshonda)
Old 03-04-2008, 10:00 AM
gursh d's Avatar
great thread. I wish I saw this before I started my swap.
FAQ worthy? I think so.
gursh d is offline
Old 05-14-2008, 03:34 PM
BlueShadow's Avatar
Default Re: FAQ My swap parts list for B18C with S2 IM into 91 CRX DX (gursh d)
zomg hai guys long time no see
Old 08-25-2009, 05:20 PM
boosted_jon's Avatar
Thanks for this thread really helpfull
boosted_jon is offline
Old 08-25-2009, 05:24 PM
CRX Toad's Avatar
Thanks for bringing back a 5 year old thread!
CRX Toad is offline
kitsume
06-19-2009 10:00 PM
1320king
11-17-2007 12:29 PM
ILOVEGIRLS
03-05-2003 12:17 AM
elmalouno
02-25-2003 02:16 AM
Quick Reply: FAQ My swap parts list for B18C with S2 IM into 91 CRX DX
