Error code 43, CRX EE8 (B16A1) (1990)
Old 05-26-2014, 10:27 AM
khems's Avatar
Default Error code 43, CRX EE8 (B16A1) (1990)
Hello in here,
This is my first post on this website.. however i have been reading various stuff in here over the years. Im from DK by the way..
It seems i need some experts to help me with an issue that really annoys me..
So i get this code 43 when reading my ecu.
4 long flashes
3 short flashes
The car runs fine when its cold.. it also starts fine. No problem.
But whenever it gets warm the engine light turns on.
Then the cars runs really akward, especially when running on higher rpm 4-5k plus. It is lagging (i am not sure what the correct english word for this is).
And the rpm counter can jump up and down in a really weird way.
Also the car will smell of fuel. Like its just burning way to much fuel off..
I can read this on the fuel counter.. it uses too much fuel.
So i have changed both O2 sensors to 2 new OEM. But that did not help at all..
Is there anyone who have some good ideas on what the problem could be ?
Your help would be much appreciated.
Thanks!
Old 05-26-2014, 11:07 AM
airesivt's Avatar
Default Re: Error code 43, CRX EE8 (B16A1) (1990)
Hi there,
I'm not sure about but: i had already a problem like that and i've changed my MAP sensor. My problem was about 44 error wich is similar but o2 sensor B - i changed it and the engine light turns on all the time; after some experiencies i've changed MAP sensor and it's fine now
if you have some friend with b16a1 you can try it. I think d16a9 MAP fits too...
(I've a EE8 B16A1 too) and it worked.
Old 05-26-2014, 02:12 PM
SpeedOFsmell's Avatar
I'm not sure how much help this will be, but this is a Honda troubleshooting guide for code 43 from my dealer's ISIS service program
Old 05-31-2020, 01:29 AM
gian_ed7b16a1's Avatar
Hi
I know that this post have been here for a while but im having a problem with this code 43 on a b16a1 it runs perfectly no loss of power what so ever and it even starts good. Any one can help me out on what to check or change??
Old 06-01-2020, 01:51 AM
airesivt's Avatar
heyo,
maybe start to check both O2 sensors. i had pretty much the same issue and at the end (changing O2 sensor, MAP, cleaning everything up, ..) it was a wire close to the ECU big connector that was "half" broken.
DReckson
05-23-2014 07:01 AM
Nonio
08-29-2010 06:22 AM
Drew96EJ
16
06-17-2004 04:18 AM
sneakypete
09-08-2003 04:46 PM
ucacrx
01-01-2003 08:24 AM
Quick Reply: Error code 43, CRX EE8 (B16A1) (1990)
