ef sometimes doesnt want to start- shortage problem?
Sometimes my ef won't crank, dash lights turn on fuel pump and all that, then when I try n crank it, it just shorts out, all lights turn off. Then what I do to turn it on is I disconnect the neg battery, then reconnect it, and I press the gas pedal and crank it and it turns on. What's my issue?
Re: ef sometimes doesnt want to start- shortage problem?
Edit* I cleaned the main ground wire that goes to tranny and neg terminal, had a little bit of green dust. Car started up fine, still don't know if it fully fixed it. I suspect either ignition wiring trouble or bad grounds. I did replace the ignition cylinder but not the wire part. I'd like to know if any one else had this issue and fixed it 100%
Garry_90Civic
07-30-2014 07:00 AM
ThaEfSwap
10-19-2011 02:16 PM
