Dohc zc help!!!!
Old 03-01-2009, 05:39 PM
lunalink's Avatar
Icon6 Dohc zc help!!!!
o.k to start off thanx ahead of time for all of your help.. o.k here's my dilemma, i have an '88 Dx CRX (auto) i know, sux..well anyway, im swapping in a DOHC ZC with a hydro trans.. i have the pedals, MC, and hydro reservoir of a Dc2 (hydro).. i need help with the wiring... i want to know what ECU i need, what harness and pretty much everything i need to know to make it work.. i know i need to make it obd1 since its obd0..do i need completely new harnesses? i have the harness that came with the zc..can i use a jumper harness to run it? or is it more complicated than that? i appreciate the help..thanx..and you guys can be cruel and evil on your posts..lol..i just need to know everything.
Old 03-01-2009, 05:54 PM
sixgunsound's Avatar
Default Re: Dohc zc help!!!!
Search y0. Most of this has been covered.
Old 03-01-2009, 05:56 PM
lunalink's Avatar
i already searched..i ended up being in the same position...can anybody help?
Old 03-01-2009, 08:02 PM
93formula's Avatar
check the faq's theres a auto to manual swap link, also a obd0-obd1 conversion link...is the dohc zc already obd1?
Old 03-02-2009, 11:52 AM
lunalink's Avatar
yeah the zc is already obd1.. i have the complete engine harness for it..and my car has a pm5 ECU, which ecu do i need? pm6, pm7 or p28? or can i use a jumper?
Old 03-07-2009, 10:21 AM
lunalink's Avatar
i checked out rywire.. are they any good?
Old 03-07-2009, 10:53 AM
jnemci's Avatar
there one of the best
Old 03-07-2009, 01:48 PM
douglaslovin's Avatar
I used rywire to modify my harness to fit a dohc zc (and they did the mpfi swap) for about $200.
The only problem is that they extra wires needed in the harness to connect to the crank shaft sensor were not there when they returned it. /shrug. just check with them about that.
PM7 ecu also.
Old 03-07-2009, 03:18 PM
lil vin's Avatar
91 crx s1 harness with a pm7 ecu thats wut i have in my 91 crx for my dohc zc....> if that helps at all....>
Old 08-17-2009, 06:20 AM
EFB055
~sp33~'s Avatar
PM7 ecu also.
Perhaps i've miss-interpreted your post, but i didn't think the obd1 dohc ZC needed extra wires for the CPS, seeing as it resides inside the distributor as apposed to the OBD0 ZC which sits on the right hand side of the exhaust cam?
Old 08-17-2009, 08:08 AM
jlicrx's Avatar
installing the OBD1 DOHC ZC in the 88 DX is not much different than installing a D16Z6 in the 88 DX
first, you need to convert the DX engine harness from DPFI to MPFI - use the injector wiring from the OBD1 ZC in making the conversion - you won't need a resistor box - you just need to add the wiring from the ECU for the 2 additional injectors and the CYLinder sensor (which is in the distributor on the OBD1 DOHC ZC)
you need an OBD1 ECU - the factory ECU for the DOHC ZC is the P29 which is the best one to use - you can also use a P06 from 92-95 DX, but it is best to have it chipped with the P29 maps - you could also use the OBD1 PR4, but it isn't going to work as well
you need an OBD0 to OBD1 ECU jumper harness and you will need to put the distributor connector from the ZC engine harness onto the DX harness
you will need to swap the driver's side engine mount from EF car onto the ZC - you may have to modify the timing cover slightly
you need to extend the wires for the MAP sensor, which is on the firewall in the DX, to reach the ZC MAP which is on top of the throttle body
you will need to remove the connector for the cooling fan switch (located on the thermostat housing on the ZC) from the ZC harness and install it on the DX engine harness (the DX cooling fan switch is on the back of the block)
if the hydro transmission you have is the DOHC ZC transmission, you will need mounts to install it in the DX - you will also need the ZC intermediate shaft and the larger axles - if the intermediate shaft is the OBD1 ZC type with male end where the axle fits, you will need a custom driver's side axle - the passenger side axle is 90 and up Integra with dust rings removed
by the way, the DOHC ZC won't pass smog in Calif
Old 08-17-2009, 03:39 PM
EFB055
~sp33~'s Avatar
Or you can block off the hole in the throttle body, and just use the existing one on the firewall.
Old 08-17-2009, 05:10 PM
BiG ChOr!Zo's Avatar
^^both you 2 are a little late on this one...he abandoned this engine a long time ago and is swapping in a b16 motor...!!!
Old 08-17-2009, 07:05 PM
EFB055
~sp33~'s Avatar
The information is always good for people who search though. Not that anyone does anymore.
Old 08-17-2009, 07:07 PM
Old 08-17-2009, 08:45 PM
lunalink's Avatar
LOL..thanx for the info guys! yeah i abandonned it a while back but the info is still very useful..
Lil ZC
14
02-11-2011 12:27 AM
the king.
12-11-2006 08:25 PM
rsdracing
06-19-2006 10:32 PM
CRXsiproject
10-10-2005 08:38 PM
ed8racer90
03-24-2003 07:23 PM
Quick Reply: Dohc zc help!!!!
