D16A8 made 102HP@WHEELS
Old 12-07-2005, 11:33 AM
  #51
crix351c's Avatar
Default Re: (vteckillenzc)
YOU ARE AN IDIOT...Your catalytic converter has nothing to do with your compression ratio......END OF STORY....Please stop talking if you dont know...
this is why most honda drivers get a bad rap...
Old 12-07-2005, 11:38 AM
  #52
zccr-xsi's Avatar
ok so u are telling me more or less backpressure dont effect your c/r?just like what everyone eles tells me PROVe it.and btw i didnt say it had everything to do with c/r.all i was saying is changes slightly without no cat.next time read lil slower dip ****.
Old 12-07-2005, 11:56 AM
  #53
be professional
Targa250R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc &raquo;</TD></TR><TR><TD CLASS="quote">ok so u are telling me more or less backpressure dont effect your c/r?just like what everyone eles tells me PROVe it.and btw i didnt say it had everything to do with c/r.all i was saying is changes slightly without no cat.next time read lil slower dip ****.</TD></TR></TABLE>
You're wrong. Whether or not there is catalytic convertor has no effect on the static compression ratio.
Old 12-07-2005, 12:09 PM
  #54
zccr-xsi's Avatar
Default Re: (Targa250R)
what bout overall c/r.cause i was told not useing a cat lowers c/r slightly.not enough to notice.when im talking bout overall c/r not c/r in each cyl.
Old 12-07-2005, 12:10 PM
  #55
Tyson's Avatar
do you know what compression ratio is?
im curious to hear what you think it is.
Old 12-07-2005, 12:17 PM
  #56
zccr-xsi's Avatar
Default Re: (Tyson)
my answer would have to be.the volume above the piston at bottom-dead-center divided by the volume above the piston at top-dead-center (TDC).
ok maybe i am wrong it might not effect it in anyway.i guess what i was told was b/s
Old 12-07-2005, 12:27 PM
  #57
Blue Hybrid's Avatar
your thinking of back pressure, it has nothing to do with compression ratio
Old 12-07-2005, 12:30 PM
  #58
Tyson's Avatar
ok maybe i am wrong it might not effect it in anyway.i guess what i was told was b/s</TD></TR></TABLE>
glad thats clear now...
Old 12-07-2005, 12:36 PM
  #59
zccr-xsi's Avatar
Default Re: (Tyson)
ok then why do on some sites i seen they are quoting 2 diff c/r for the zc and the one with no cat has low c/r
9:3.1&lt;&lt;witout cat
9:5.1&lt;&lt;with cat
are they just blowing **** out there *** or what
  #60
NACvicSi's Avatar
Anyways back on track. OP, nice number for a stock ZC.
Old 12-07-2005, 12:41 PM
  #61
zccr-xsi's Avatar
Default Re: (NACvicSi)
damn man to see a stock zc dyno out at 102 hp thats kinda depressing.i thought it had more then that.i need to dyno mine now.
Old 12-07-2005, 01:13 PM
  #62
NACvicSi's Avatar
Loss is between 15-17% thats what we said. Thats in tip top shape, I'm sure this one is loosing more because it's an older engine.
Old 12-07-2005, 01:17 PM
  #63
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc &raquo;</TD></TR><TR><TD CLASS="quote">ok then why do on some sites i seen they are quoting 2 diff c/r for the zc and the one with no cat has low c/r
on UK crx, they offered SOHC and DOHC engines. compression ratio on DOHC engine is 9.5:1, however they offered two SOHC engines with cat, and without for use with unleaded and leaded fuel respectively. the difference of compression ratio was 9.5:1 with cat, and 9.1:1 without cat.
seeing that the bore and stroke remained the same between unleaded and leaded fuel engines, then the pistons were different which leads to a different compression ratio. its not that having the cat or not changes the compression ratio, its how the engine was designed for use with or without a cat. removing the cat on an engine designed to utilize the cat doesnt change the compression ratio of the engine.
http://media.honda.co.uk/car/o...8.pdf
Old 12-07-2005, 03:41 PM
  #64
SINISTR's Avatar
Wouldnt the Compression Ratio you're Refering to be also different because of different Gens of ZC motors?
Brown Top (~84-85) would have the lower C/R over the Blacktop ZC (~87-92) would have the 9.5/6:1?
If you measure the C/R of each cylinder - you're doing it without the exhaust even operation - motors turned off... so the CAT has nothing do do with the Comp Ratio. - its Backpressure that makes a diff.
CATS are designed to flow easy anyway - a NEW CATs flow will be equivalent to a HighFlow CATS flow... when you run the car for 10yrs its reducing the flow - increasing BackPressure.
Old 12-07-2005, 04:40 PM
  #65
zccr-xsi's Avatar
Default Re: (SINISTR)
i think i was confuseing back pressure for the cat
Old 12-07-2005, 05:20 PM
  #66
South Bay Surfer's Avatar
Location: South Bay, Torrance/Carson, CA, United States
102 whp? damn you got me scared to dyno my dohc zc. but i need to know the truth one day.
Old 12-07-2005, 05:23 PM
  #67
NACvicSi's Avatar
Default Re: (CarsonSurfer)
Really. I want to dyno my new motor but I'm scared, if it's bad I might get pissed lol
Old 12-07-2005, 05:28 PM
  #68
If my motor were to dyno that low I would give up on that motor.
Old 12-07-2005, 05:30 PM
  #69
zccr-xsi's Avatar
damn thats still dont sound right.i wonder how much hp a b16 would lay to the wheels.what like 130?
Old 12-07-2005, 05:31 PM
  #70
my stock b16 made 134 on a chassis dyno
Old 12-07-2005, 05:40 PM
  #71
Im hoping for at least 110-115 whp with my dohc zc w/i,h,e, and testpipe. ****, my d15b w/i,h,e vafc, hi flo cat, fpr, pulleys cam gear--all untuned made a baseline of 115 whp. After it was tuned it made 123whp and 98lbs of torque.
Don't the dohc zc and d15b both make 130ps?
If my dohc zc puts up similar baseline numbers I'll be all smiles.
Old 12-07-2005, 06:05 PM
  #72
zccr-xsi's Avatar
i dont even want to think what mine will put down.im already planing on ls/vtec now.im ashamed of my zc now.
Old 12-07-2005, 11:22 PM
  #73
SINISTR's Avatar
Guys - Sorry - but do you even read 'complete' posts or just pick all the stuff you 'want to' hear and reply to that? - its becoming annoying.
Australian DYNOS read LoWER than most other Dynos. B16As on the day got about 120HP, worked B18Cs got 150HP.
This conversation has been going on for 3 pages now and you still come back telling me it TOO LOW for a ZC. Obviously US dynos are calibrated alot better than Australian Ones.. at the end of the day its not good to compare dynos anyway - its more a tuning tool.
With all of your 110/115WHP how quick do you guys go down the 1/4? cos thats a better indicator of the HP than a Dyno anyway. With 115whp you guys should Id assume get a mid 15 second pass in a street trim car...???
Pls don't take this the wrong way im only mucking around - but obviously when Japan made ZCs for the US market they gave you the better ones didn't they? so while in Australia we only get 100hp you guys get 115hp more! WOW.. im moving to US - maybe my D16A8 will make 130@wheels???
Old 12-07-2005, 11:39 PM
  #74
SINISTR's Avatar
Default Re:
These are the dyno HP readouts that we got on the day - for you guys to compare.. You'll realise its all the cars reading LESS than what you guys think - simply because of the different Dyno calibrations...
owner car engine dyno 1 dyno 2
nsx c32a 225hp 237hp
eg8 zc (jdm) 97.3hp 99.9hp
eg9 d16a8 (jdm) 85.9hp 88.7hp
crx zc 95.8hp 98.3hp
crx d16a8 99.1hp 102.0hp
ek1 d16y 93.2hp 93.3hp
ek1 d16y 91.0hp 93.1hp
eg8 d16y1 85.9hp 89.9hp
eg5 d16y1 100.1hp 99.6hp
em1 d17a 99.9hp 100.7hp
ej8 d16y8 101.8hp 104.6hp
ef9 b16a 109.6hp 113.4hp
eg5 b16a 120.6hp 121.9hp
eg4 b16a2 130.6hp 132.5hp
ek4 b16a2 122.3hp 120.9hp
eg4 b16a 119.2hp 119.7hp
del sol b18c 141.7hp 145.2hp
ek4 b18c 146.2hp 147.0hp
da8 b18a 97.1hp 97.9hp
teg gsi b18b 103.3hp 104.1hp
ek4 b16a2 111.2hp 111.9hp
dc5r k20a 153.2hp 148.6hp
dc5r k20a 148.0hp 150.1hp
dc5r k20a 156.1hp 159.4hp
pulsar sr20de 115.3hp 117.7hp
prelude h22a 143.3hp 144.2hp
ef - 67.6hp 66.8hp
s2000 f20c 171.6hp 177.0hp
dc5r k20a 150.6hp 150.2hp
Old 12-08-2005, 06:43 PM
  #75
kantfadedisazn's Avatar
Default Re: D16A8 made 102HP@WHEELS (SINISTR)
just a question ur d16a8 is that the single cam jdm zc cuz that is wat i hav, as for low buget mods that make good power since u allready hav IHE take a d16y8 intake manifold and bolt that on its like the type r manifold for single cam, second add on the exospeed sr909 cam it makes really dam good power and only costs $200 the specs are 294 degrees 304 duration, another cheap mod is the racing crank pully from unorthadox u gain some power there, and last but not least an ecu from prospeed they know how to work their magic on sohc. thast wat ima going to do so hopefully that helps u out anyway
Quick Reply: D16A8 made 102HP@WHEELS
