d16a8 adjustable cam gears??????
Old 07-01-2006, 10:32 AM
MANDO6669's Avatar
Default d16a8 adjustable cam gears??????
okay ... i need to find some adjustable cam gears but i dont know if the cam gears are the same from a zc2 or d16a1 .... suggestions?
Old 07-01-2006, 10:57 AM
MANDO6669's Avatar
anybody know of some cam gears that would fit my engine?
Old 07-01-2006, 01:39 PM
Lamchop0000's Avatar
Default Re: d16a8 adjustable cam gears?????? (MANDO6669)
are you sure its a A8 motor?
Old 07-01-2006, 02:30 PM
MANDO6669's Avatar
Default Re: d16a8 adjustable cam gears?????? (Lam.N)
yea ... its only stamped on the block. i put it in.
but yea ... cam gears for this thing????
Old 07-01-2006, 06:14 PM
johnjw's Avatar
bump for interest in your motor, never seen that valve cover/motor. where did you get it?
Old 07-01-2006, 06:29 PM
Sikocivic's Avatar
Default Re: d16a8 adjustable cam gears?????? (johnjw)
Those motors are the same as a DOHC ZC motor but they come out a Rover in England.
Old 07-01-2006, 06:35 PM
Hamstr323's Avatar
edm valve cover? as far as the cam gears try jg engine dynamics they might still make them
Old 07-01-2006, 11:18 PM
MANDO6669's Avatar
okay i found that cam gears that they make for the zc at jg engine dynamics ... but on there application guide it says that the d16a9 cam gears are not interchangeable, it didnt say anything about the a8 but to my knowledge the only difference from the a8 and a9 is cat converter.... can you guys prove me wrong???? i dont want to go buy'em to find out that they dont fit.
Old 07-02-2006, 01:44 AM
Default Re: (MANDO6669)
oh, intresting motor. about the cam gears, when i had my DOHC ZC i used JG cam gears, and im sure i got the B series model.
can you get a count of how many teeth are on your cam gears?
i can get pictures of my Dohc zc factory cam gears for comparison refference so you can compare them to yours. and if they match. you should be good with any B series cam gears.
Old 07-02-2006, 06:50 AM
civicjdmb16a's Avatar
Default Re: (Lam.N)
I also had a dohc ZC and i had b series cam gears
Old 07-02-2006, 08:16 AM
SlobberGoat's Avatar
Default Re: (civicjdmb16a)
I've always thought the D16A8 and the D16A9 engines were identical..
Old 07-02-2006, 10:07 AM
Default Re: (SlobberGoat)
I did to. I read somewere that the only diff was one came w/out a cat
Voodooboy520's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlobberGoat &raquo;</TD></TR><TR><TD CLASS="quote">I've always thought the D16A8 and the D16A9 engines were identical..</TD></TR></TABLE>
Then why the difference in name?
BTW, I like that engine. If you ever want a DOHC ZC cover I'll trade you.
http://www.thezcr.com
Old 07-02-2006, 10:08 AM
Found this on hybrid honda
There are three versions of the ZC that I am aware of, but there could be more
D16A8 Euro. spec featuring EFI
D16A9 Euro. spec featuring Carbs
ZC Jap. spec featuring EFI
Old 07-02-2006, 10:41 AM
Autoworks's Avatar
Use the DOHZ ZC cam gears from JG.
Old 07-02-2006, 01:04 PM
MANDO6669's Avatar
i also i thought i read somewhere that the d16a9 is meant to run on leaded gasoline ... it also has lower compression if i am correct... let me see if i could find that link again.
Old 07-02-2006, 06:41 PM
MANDO6669's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lam.N &raquo;</TD></TR><TR><TD CLASS="quote">oh, intresting motor. about the cam gears, when i had my DOHC ZC i used JG cam gears, and im sure i got the B series model.
i can get pictures of my Dohc zc factory cam gears for comparison refference so you can compare them to yours. and if they match. you should be good with any B series cam gears.</TD></TR></TABLE>
okay i got a picture of the cam gears my self, i believe it has 34T how about yours?
does pm7 mean anything?
Old 07-02-2006, 06:44 PM
looks the same haha...
Old 07-02-2006, 06:47 PM
MANDO6669's Avatar
okay so what kind did you get???
are they like these?
http://www.swapshopracing.com/....html
Old 07-02-2006, 07:01 PM
yeah mine were just like that but silver. i think all JG camgears had the same design...
if they still offer the ZC model i would get that. because honestly i got rid of those back in 2002. so i may have got the ZC instead of the B series. but when i sold it... i sold it as a B series cam gear. so maybe it was B series. HA
and i also recall comparing them side by side with a skunk2 b series cam gear. and the skunk2 had more off an off set, but other then that it had the same teeth count and diameter.
oh yeah, the JG cam gear teeth was horrible, and jaggy, and the bolt stripped easly, that was another reason why i sold them. they wernt nice as the skunk2's
MANDO6669's Avatar
Default Re: (Lam.N)
okay i think i found them .... i saw this link on jgenginedynamics.com
http://jgenginedynamics.com/Ad...E.pdf
Old 07-02-2006, 07:08 PM
MANDO6669's Avatar
okay ... well i got an idea of what to look for ... atleast i know that they are the same as the cz ... hey , what diameter is that aneway? ... skunk2 have cam gears for cz??
thanks alot ...
Old 07-02-2006, 07:11 PM
MANDO6669's Avatar
hey skunk2 is like the down the street from my house.... damn .... i should just stop by and ask..... !!!!
Old 07-02-2006, 07:15 PM
no skunk2 does not make a ZC version, but B series is what you would use... and that goes for AEM, fidanza, ETC.
like i said, the offset is the only difference...
Old 07-02-2006, 07:23 PM
MANDO6669's Avatar
Default Re: (Lam.N)
yea ... i was lookin at that already ... im doing this for performance engine tuning class for my school that im taking ... and i get to use the dyno as much as i want, as long as i dont venture off to many degrees to cause an interference i should be able to tune it to its capacity... heheheh .. quick question ... is the d16a8 an interference motor aneway?
m R g S r
02-24-2006 02:05 PM
1998IntegraLS84
07-24-2005 06:55 PM
hondacivicjosh
11-02-2004 11:20 AM
Quick Reply: d16a8 adjustable cam gears??????
