b16 ed6 wiring help!!!
ive been looking around here for a while and i can not find any good information on doing the engine wiring any help would be appreciated like do i need plugs off of the b16 harness or do i just use the d15 plugs oh its gonna be obd1 again please help i would post pictures but i dont feel like putting them on photobucket and then on here
Re: b16 ed6 wiring help!!!
it is a dx i know i have to do the v tec stuff but im thinkin i need some plugs off of the 2000 si harness. i know i need to do the injector plugs but im not sure what to re use or what
First you have to convert dual point to multipoint fuel injection and then you can worry about dizzy wiring, injector wiring, and depending on if your staying obd0 or converting to obd1 ecu obd1 use a 4 wire o2 sensor, then you worry about vtec
i already have multi point im doin the ecu this weekend. i wanted to know about the plugs i need like alternator t stat and if there are other i just seem to have more plugs than i need
Start with this: what year is the motor? And what all came with your swap. This will determine what wiring mods will need to be done
i need some help i have a 91 ef hatch that im doing a b16a2 with a gsr head swap to and im trying to figure out what wiring harrness i need to start with and what all i need to do to it im running an aftermarket intake manifold i have 4 harrnesses here the gsr harrness a ls to ef conversion harrness a regular ls harrness and my stock ef harrness buddie had it all planned out and was going to help out but flaked any help would be awesome
SOHCEK-Turbo
11
03-06-2005 09:32 AM
turbo_civic_ek
10-28-2004 02:16 AM
MHhonda99
10-20-2002 07:21 PM
