H22 or K20
Re: H22 or K20 (iNDiO)
Here's a big thing you have to ask yourself: Do you have to smog the car? If so, forget the K20. It is IMPOSSIBLE to BAR a K20 in California. On the other hand, if you run the H22A with the proper P13 ECU and use all the proper smog gear, you can BAR it.
Re: H22 or K20 (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">Here's a big thing you have to ask yourself: Do you have to smog the car? If so, forget the K20. It is IMPOSSIBLE to BAR a K20 in California. </TD></TR></TABLE>
isnt there ONE bar'd k20 EG hatch in CA?
its not easy to do because of the returnless fuel system and immobolizer in the ECU. but i remember the guy saying something about swapping the gas tank, unchipped ECY, and full dashboard to bar the car.
Re: H22 or K20 (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">
its not easy to do because of the returnless fuel system and immobolizer in the ECU. but i remember the guy saying something about swapping the gas tank, unchipped ECY, and full dashboard to bar the car. </TD></TR></TABLE>
There's also the issue of the header. The stock manfold won't fit. And I'm SURE there isn't a CARB approved piece available that will fit an ED/EF.
There's also the issue of the header. The stock manfold won't fit. And I'm SURE there isn't a CARB approved piece available that will fit an ED/EF.</TD></TR></TABLE>
There is one in cali. If you search hard you will find it, was on here like a yr ago. He swap everything from a wreck rsx into a eg hatch, dash, full wiring, hardlines, gas tank, anything making the rsx run and some cosmectic stuff he swaped into the hatch. Bar and Carb legal, but once that was done i believe they swap in a k20a they had orginally for that car.
Re: H22 or K20 (CR91X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CR91X »</TD></TR><TR><TD CLASS="quote">What they said considering you're in CA but if you weren't I would have to say K!!! Cuz that's what I want! K+crx=12s=fun </TD></TR></TABLE>
Left Kidney+Left ********=Kseries swap.
Re: H22 or K20 (SIred91)
I also say h2b if you lack funds but get the k20 if money isn't an issue to you. They're performance will be very similar, besides the H making more torque
Re: H22 or K20
Go with the setup that you can afford to break!
If you can afford to replace broken parts on a k-series setup go for it..
Or else you'll be another one of those douches who go with a k-series just for the 'show' factor; spending a pile of cash just to baby the car.. :S
crazy mad murdock
