need help with tack
need help with tack
i have a crx with a JDM B16A as you all no the dizzys suck ha... well i just put a new dizzy in and now the damn tack is not working what would it be any help would be good im just a dumb body guy thanks a lot
Re: need help with tack
Is it possible you dislodged the speedo cable from the tranny housing? Its possible while your unbolting the dizzy, especially if you removed the battery and intake tube.
the speedo cable has nothing at all to do with the tach... im guessing if it happend when you changed the dizzy that there is somethin wrong with it or maybe some wires got pinched or somethin... gotta be something along those lines...
I would say its somewhere in the dizzy, cause your vtec runs off your dizzy also, My boys gsr dizzy started messing us and vtec didnt kick hard along with the tach, the tach sarted to flicker.
this is the wiring chart for the dizzy clips... i was wrong about the green and white wires lol... and idk what wire is for the tach.. but either way the cilps from the dizzy include a wire for the tach... this i know... so just make sure none of them are pinched anywhere... that about all i can say i dont know much about the dizzy itself except that they go bad and how to replace its parts...
be professional
It's very likely that the ignitor in your new distributor is bad. I've had a few brand new ignitors come straight out of the box with the tach output signal not functioning.
yea those aftermarket dizzy's have all types of problems all the time... i hate them... i would just go buy one straight from honda...
take off the cap and look at the igniter and check if the blue wire came off the igniter there should be 4 wires i think and the rpm wire witch is blue should be on the side of the igniter right next to the coil
hey thanks a lot you guys it was the igniter i took the igniter out of my out one and everything is working fine ha its nice to no what rpm your at agein
