Clutch shudders when engaging
Old 08-31-2002, 09:05 AM
Malgerus's Avatar
Default Clutch shudders when engaging
I'm using a 96' Y8 clutch disk and pressure plate with my 89' tranny. When I put it in first and ease the clutch out to get moving, the whole car shakes like mad. I've adjusted the engagement, so I figure it must be something to do with the way I've installed it. Is it likely that the pressure plate or throwout bearing is royally screwed? It still engages well when I actually race at the strip (sometimes chirp 3rd), it's just stop and go driving that is REALLY unpleasant.
Old 08-31-2002, 10:59 AM
speeddave's Avatar
Default Re: Clutch shudders when engaging (89_Y_49)
maybe dumb question but did you resurface the flywheel? if the clutch was new and the flywheel needed to be resurfaced, that will make it chatter.
[Modified by speeddave, 8:00 PM 8/31/2002]
Old 08-31-2002, 01:27 PM
Phatwhippin_CRX's Avatar
Default Re: Clutch shudders when engaging (speeddave)
Also, really harsh pressure plates will make the clutch chatter..
Old 08-31-2002, 02:11 PM
.nate's Avatar
Default Re: Clutch shudders when engaging (Phatwhippin_CRX)
clutch chatter... get used to it
Old 08-31-2002, 02:24 PM
havok hybrid's Avatar
the clutch u put in.. is it a aftermarket... is it a puck clutch .. if so.. then it is just the clutch workin.. u cant ride a puck clutch.. because it will just chatter
[Modified by havok hybrid, 11:24 PM 8/31/2002]
Old 08-31-2002, 04:14 PM
Malgerus's Avatar
Default Re: Clutch shudders when engaging (havok hybrid)
The clutch is a stock 96' disc and pressure plate. It's a cheap "dyna pack" brand ( In knew I should have went with stock honda but damn it's expensive). I had the flywheel machined too. It does have a lot of "chatter" (by chatter I mean it makes noise until I press the clutch past the engagement point) but the shaking is NOT normal. The whole frickin' car shakes it's very annoying. I have to drive it in a certain way so that the shaking won't jar me or the passenger. Someone pointed out to me that I'm missing the top bolt on the front mount that attaches to the crossmember and tranny. when I rev it, the engine flexes, but I don't think that's the entire cause of my problem. I need another bolt, but the wreckers are all closed until tuesday... (stat holiday on monday here)
[Modified by 89_Y_49, 1:16 AM 9/1/2002]
Old 08-31-2002, 08:38 PM
MrTodd's Avatar
You'll have to post the solution once you find one!!!
I have pretty much the same problem - but I'm positive that it's because my flywheel or maybe the pressure plate (or both?) have an uneven surface now. I didn't really break in my new clutch properly when I got it..... Now this thing chatters like mad, the whole car can shake big time. It's very annoying.
Good Luck
SSJSubgeta
10-22-2005 12:20 PM
-[95cxhatch]-
03-01-2004 01:22 PM
2000turbosi
11-03-2003 06:20 PM
Razor
07-19-2002 08:33 AM
Quick Reply: Clutch shudders when engaging
