clutch pedal/cable squeak is annoying me!
what can i do to get rid of that annoying squeak!??! im sure a lot of you guys have this!
Re: (Blaze45)
yeah i HAD the same problem. i replaced the clutch cable itself (not just for this squeeking but for other reasons) and it still happened, so i knew it wasnt the cable. SO.... i bought a can of lubricating oil and stuck my head under the dash where the assembely is. and you need to lubricate the assembely where the cable connects to the pedal. and there is a spring you need to lube up as well. (if i remember correctly) its VERY simple and it has never happened since. good luck
Re: (OneSlowEF)
a can of wd40 would do? so i guess ill just stick my head under there and spray away...how long did that smell stay in your car?
Re: (89civicdx)
change the spring for the clutch pedal. its located under the dash at the top of the pedal. this should cure the squeak. or you could lube the top of the pedal where the bolt and nut is.
be professional
Re: clutch pedal/cable squeak is annoying me! (crashtest Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crashtest Sonny »</TD></TR><TR><TD CLASS="quote">what can i do to get rid of that annoying squeak!??!</TD></TR></TABLE>
First you have to get up under the dashboard and find out exactly where your squeak is coming from.
Re: (crashtest Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crashtest Sonny »</TD></TR><TR><TD CLASS="quote">a can of wd40 would do? so i guess ill just stick my head under there and spray away...how long did that smell stay in your car? </TD></TR></TABLE>
wd40 is not a lubricant, is a disolvant man.
use some white grease to lube the bushing and the spring.
if you whant to feel the pain in your *** doing this, you can also make the whole trip to remoove the cable assembly and lube it goooooood with some grease and reassemble it, put it back into place. I did this when doing my auto to manual conversion
Kranked
Kranked
Re: clutch pedal/cable squeak is annoying me! (CyniKal.Mindset)
how bout some silicone spray? i just started noticing the squeaking a couple of days ago. damn irritating the hell out of me specially in traffic
philkehn
18
09-14-2006 04:49 PM
1RMDave
01-27-2006 04:33 AM
