Engine temp
Old 11-19-2009, 11:42 AM
jakop92's Avatar
Default Engine temp
Got a 89 HF.. just replaced the thermostat (/w OEM) and flushed the rad.. filled with 50/50 antifreeze.
The temp gauge never ends up in the middle.. always slightly lower. Heater doesn't blow hot air.. but rather, warm air. I can park the car and let it idle for 20 min and the rad fan will never turn on. Or at least I've never heard it turn on. Car never overheats.. but like I said the needle never reaches half way.
Is this normal or what should I diagnose for problems?
Old 11-19-2009, 12:02 PM
D16SiHatch's Avatar
Default Re: Engine temp
the needle should never get to halfway or surpass it, it should be always be just below half.
the cable might be muffed up at the control box in the car, or for some reason the hot water valve in the engine bay might not be opening all the way.
valve closed
valve opened (where it needs to be in order for coolant to flow and to get heat in the car)
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/heat-not-working-2225295/
Old 11-19-2009, 12:38 PM
jakop92's Avatar
Thanks for the pics & link. Valves were not fully open. The heater now blows hot. And about the needle.. it's at the correct temp setting then. Thanks.
Old 11-19-2009, 12:42 PM
BiG ChOr!Zo's Avatar
my needle always stays a little over 1/4 but never reaches half way...!!!
MinimusMaximus
20
12-17-2016 03:46 PM
CUTTERSPOOL
10-21-2012 11:05 AM
litterbox
03-16-2009 06:50 AM
Since 1983
04-29-2008 12:23 PM
Quick Reply: Engine temp
