Car wont start on first turn of key but starts the second time
Old 08-15-2007, 09:24 PM
90_Si's Avatar
Default Car wont start on first turn of key but starts the second time
I did a search and did not come up with a whole lot that was applicable. The engine is a sohc zc. In the morning when I start it, it will not start the first time.. but on the second time I turn the key it starts perfectly.The main relay came to mind, but usually it is the opposite. The engine has a new timing belt, distributor cap/rotor, water pump, spark plugs, ignition wires.. basically anything that would ever wear out has been replaced. It has also had a can of seafoam ran through the fuel/vacuum/crank case. The distributor cap and rotor made the start much smoother and such in general terms, but did nothing as far as the issue at hand. It only happens in the mornings, so once it has been driven for the day it starts just fine. It seems the engine has to completely cool down for it to start the delayed start. I am at a loss for what it could be, any help or ideas would be appreciated.
90_Si is offline
Old 08-15-2007, 09:41 PM
garageEF's Avatar
Default Re: Car wont start on first turn of key but starts the second time (90_Si)
bump cause im having a similar problem.
garageEF is offline
Old 08-15-2007, 10:48 PM
EFM_ookie's Avatar
Default Re: Car wont start on first turn of key but starts the second time (garageEF)
can u hear the main relay click when it doenst start?
EFM_ookie is offline
Old 08-15-2007, 11:00 PM
90_Si's Avatar
Default Re: Car wont start on first turn of key but starts the second time (EFM_ookie)
No, everything sounds normal other than it wont actually start on the first turn of the key. The weird thing is is that on the first go round I can let it turn over 10 times or two times and it wont start, but in either case if I let the key off and then turn it the second time it starts right up completely normally. It does this on every single cold starts, but once it has been started, whether for just a second or driven all day it starts normally until the car sits overnight and then the problem arises again.
90_Si is offline
Old 08-15-2007, 11:01 PM
garageEF's Avatar
try priming your fuel pump a few times before trying to start it.....just to see if it is a fuel pressure issue.
garageEF is offline
Old 08-15-2007, 11:05 PM
90_Si's Avatar
How do I prime the fuel pump?
90_Si is offline
Old 08-15-2007, 11:08 PM
garageEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_Si &raquo;</TD></TR><TR><TD CLASS="quote">How do I prime the fuel pump? </TD></TR></TABLE>
just click the key to "on" a few times...you will notice the check engine light coming on, then turning off after a few seconds...that is your pump priming.
garageEF is offline
Old 08-15-2007, 11:14 PM
90_Si's Avatar
just did it and after priming it it started normally. I am assuming it has sat long enough to have cooled to where the issue would arise.. I will do it again in the morning to make sure. That fits my assumption that it is something to do with the fuel system. As far as fixing it, is it going to be a matter of having to get a new fuel pump?
90_Si is offline
Old 08-15-2007, 11:35 PM
garageEF's Avatar
definatley a fuel issue.....when you turn your car off...there is enough fuel in the system for it to start normally for an hour or so....im sorry but i have no idea where you would start to diagnose your problem...best of luck to you
garageEF is offline
Old 08-16-2007, 12:02 AM
90_Si's Avatar
well at least I know specifically where to look for the problem now, thats a start.
90_Si is offline
Old 08-16-2007, 12:22 AM
garageEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_Si &raquo;</TD></TR><TR><TD CLASS="quote">well at least I know specifically where to look for the problem now, thats a start. </TD></TR></TABLE>
your welcome
garageEF is offline
Old 08-16-2007, 12:36 AM
i_VTEC's Avatar
The same thing happens to my 88 CRX Si. The first start of the day, when i try and start the car it turns over and sounds fine, but it wont start. But as soon as i do it the second time it starts right up........
i_VTEC is offline
Old 08-16-2007, 12:45 AM
garageEF's Avatar
Default Re: Car wont start on first turn of key but starts the second time (LS-VRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS-VRex &raquo;</TD></TR><TR><TD CLASS="quote">The same thing happens to my 88 CRX Si. The first start of the day, when i try and start the car it turns over and sounds fine, but it wont start. But as soon as i do it the second time it starts right up........ </TD></TR></TABLE>
well now you know what the problem is....
garageEF is offline
Old 03-15-2013, 05:32 PM
sorwdfish's Avatar
its your ignition key starter. switch it out... every time my car sounds funny i take it in to the mechanics and have them diagnose my car for free. then they tell me the problem so i tell them ill come back when i get payed and never do so i know whats wrong with my car for free.
sorwdfish is offline
Old 09-17-2014, 08:38 AM
drhonda's Avatar
I realize this is really really old, but did someone ACTUALLY figure out the solution?
drhonda is offline
Old 09-17-2014, 09:11 AM
cjwang2's Avatar
I had this problem recently. I changed my Fuel Pressure Regulator and the car starts up right away each time now.
cjwang2 is offline
Old 09-17-2014, 10:57 AM
drhonda's Avatar
Time to find the fuel pressure guage.
drhonda is offline
Old 09-17-2014, 12:10 PM
Tyson's Avatar
sometimes its the ignition switch in the key assembly in the steering column. (this was pointed out earlier btw, did you try??) spray some WD40 inside.
sometimes its the battery connectors not being tight enough.
sometimes its the starter.
never heard of the fuel pressure regulator being an issue tho... but if they say so...
Tyson is offline
Old 09-17-2014, 04:22 PM
drhonda's Avatar
I get spark in the no start first crank situation. I don't see what wd40 would do to my key? I've driven cars with a bad ignition, this is not one.
The battery? No. The car will sit for days and fire right up.
The starter? No, it turns over just fine and fast.
THis is my thoughts on fuel pressure regulator. I can prime it as much as I want still no start on the first try. Second try it fires up like it should. Mine is temperature dependent, summer months its fine. Its only when its colder. Back to my theory. The fuel pressure regulator works on vacuum, well, there is zero vacuum without the motor turning over. So once the motor turns over a couple times it creates enough vacuum for the fuel pressure regulator to do its thing. Hence why it start flawlessy the 2nd attempt. The seal on mine must shrink just enough to not seal in the cold and lose it over night. During the day the engine holds temp long enough and sitting in the sun must be enough to expand that seal. Once I find my fuel pressure guage I will know soon enough. The cheapest one I found was at napa for $65. I'm a mechanic not a parts changer. I diagnose. Especially on a car with 250k miles and it still starts.
drhonda is offline
Old 09-17-2014, 04:27 PM
Tyson's Avatar
thanks for the explanation. glad ive never had to deal with this issue myself.
so why'd you ask??
oh, regarding fuel issues, ive also found that it takes a lot of cranks to get it started, particularly when sitting overnight. priming the system by turning the ignition half way and then back again before fully cranking helps reduce the number of cranks to start a lot.
what i've found is that the injectors are leaking internally around the electrical contacts and causing a loss of fuel pressure. the injectors also get really dirty, particularly around the manifold and its clear to see which one(s) is leaking the most.
cant fix the injector, need to replace.
Tyson is offline
Old 09-17-2014, 04:34 PM
drhonda's Avatar
Because this is a forum, there was a question, in my opinion it was never answered. People use this for information. So later down the road if someone else has this issue this maybe a place for them to start diagnosing their own problem.
I unfortunately am going through this issue and did a google search to see if someone else had the issue. I have already, tested, coil, ignitor, cleaned out FITV, IACV, new rotor, cap, plugs, wires. I'm ready to test fuel. Unfortunately a buddy borrowed my guage and he's on vacation, so I'm going to have to wait a week.
drhonda is offline
Old 09-17-2014, 04:39 PM
Tyson's Avatar
btw, if the question really hasnt been answered in an ancient thread, its best to START A NEW THREAD. that way ppl reading the thread dont have to go thru a bunch of useless posts.
if you REALLY want to reference an old thread, just link it. and THEN ask the question.
that way it will REALLY be useful "later down the road".
I also don't need to provide technical advice.
youre not very good at it...
Tyson is offline
Old 09-17-2014, 04:43 PM
drhonda's Avatar
drhonda is offline
Old 01-29-2019, 10:02 PM
CyBiL Ization's Avatar
Umm...For the record, his information IS REALLY useful "later down the road" because look... Here we are... And it is now "later down the road" and the info I just read about the fuel pressure regulator problem was really helpful to me in diagnosing the problem that I am having with MY car now. So, it actually was really useful to include it in THIS thread after all.
What ISNT useful is a comment like yours, with no information about car repairs whatsoever... just reprimanding someone about petty nonsense. People come to this forum to find information about how to fix their cars...not to read someone's petty, meaningless gripe of the day. The only part of this thread that is USELESS is the part that YOU wrote.
CyBiL Ization is offline
Old 01-29-2019, 10:45 PM
-Intl Steve Krew
Caoboy's Avatar
You know what's really useless?
Making a useless post about how useless somebody's post was from five years ago.
That is really useless.
Caoboy is online now
Quick Reply: Car wont start on first turn of key but starts the second time
