Car wont start.
Old 12-18-2009, 03:47 PM
4tika4's Avatar
Default Car wont start.
Okay. So today i went to work. My car started fine. Then when i went to take my lunch break, it wouldnt start. It was cranking over then it would start, but as soon as i would let go of the key from the ignition position, it would die. So i kept trying it. And i remembered it did it a few times before, so i gave it some gas when it fired up and it stayed running.
So I started driving after i let it run for a little, then i let off the gas and pushed in on the clutch because i needed to stop. And it just died. I had only made it around the corner from my work. So i pushed it into a lot and left it for a while.
Then about 30 minutes later I tried again a couple times. And I finally got it to start. So I hurried and drove it back to work and parked it. I let it idle for a while, I checked my fuel pressure gauge and it surged down low. So I shut it off.
By now I was thinking it was the fuel pump. Does anybody think it could be the fuel pump? I tried it again after work, but still no luck. So I got a ride home. I couldnt hear it when i would turn the key to the on position.
My car has kinda acted weird prior to this. It would idle low alot. It sometimes felt sluggish when i would get on it. It would sorta hesitate if you gave it throttle real quick.
any ideas?
Old 12-18-2009, 04:42 PM
35r'DHyBriD's Avatar
Default Re: Car wont start.
fuel pump and filter is where i would start ... then on to the injectors and so on and so forth
Old 12-18-2009, 06:37 PM
4tika4's Avatar
this sucks
LSVTECTEG18
05-16-2008 09:37 PM
BlueLude84
01-13-2007 10:11 PM
rice is nice
11
05-02-2005 11:15 PM
vxnine
13
09-26-2004 05:17 PM
chrisITR
11-05-2002 12:02 PM
Quick Reply: Car wont start.
