Little problems since d15b7 swap HELP!
Old 04-05-2006, 07:56 PM
Reego.'s Avatar
Default Little problems since d15b7 swap HELP!
so I put 95 D15b7 in my daily driver(91 civic lx sedan), I used the dpfi manifold,and now Im having problems with the idle,in the morning when I turn on the caritdies and I have to keep my foot on the gas pedal until it warms up, I usually keep it at like 1000 rpm,also when driving and whenIm on low rpms the car kind of bogs,whatcan be causing this? I also have a CEL,but dont know how to read it, I need some help Please, thanx in advance
Old 04-05-2006, 08:25 PM
crxnj's Avatar
Default Re: Little problems since d15b7 swap HELP! (Reego.)
Fix that code and maybe the problem will go away https://honda-tech.com/zerothread?id=468260
Old 04-05-2006, 08:37 PM
HatchWarehouse's Avatar
To check your code:
Pull the carpet on the passengers side floor
You can see a small clear circle, it should be blinking
(ex. ..... blink blink..... blink blink..... blink blink..... equals Code 2)
count the number of times the light blinks in a group.
When you have the number or numbers search for "ECU codes" here, you'll
find what the code means and the reason why.
Your engine problems are most likely related to this.
After you fix the problem remember to reset your ECU or else it won't know you fixed it.
Do this by either unpluging the negative battery cable and waiting about 5 seconds or removing the ECU fuse on top of the passengers side strut tower under the hood and waiting around 5 seconds.
This basic info should help you, let me know how it goes
Old 04-06-2006, 08:04 PM
Reego.'s Avatar
i have codes 5 and 10
EM1_00Si
12-26-2007 12:32 AM
gsrturbo-ek
04-19-2006 07:31 PM
99redb16a
01-18-2005 10:26 AM
88bottlefedcrx
01-29-2004 03:12 PM
Quick Reply: Little problems since d15b7 swap HELP!
