car is running really ruff smells like gas to HELP!
Old 03-25-2011, 08:13 PM
N'viouzEF9's Avatar
Icon3 car is running really ruff smells like gas to HELP!
my car ran fine then some wires that were really weak on my jumper harness broke finally so i ordered a new one well once i put it on i turned on the car and it idles really rough and smells like gas do u guys know what it can be i drIve a 88 ef dx mpfi wired with rywire n obd1 d15 could it be my battery or alternator? fyi car barley turned on in like a week any help thanks i need this fixed
Old 03-25-2011, 08:18 PM
BiG ChOr!Zo's Avatar
Default Re: car is running really ruff smells like gas to HELP!
check the condition of your fuel injector seals and your fpr...i had a similar problem and swapped my fpr and i've been getting over 300 miles on a full tank and the gas smell went away...!!!
Old 03-25-2011, 08:31 PM
N'viouzEF9's Avatar
thanks ill check that out but do u think that will happen out of no were?
Old 03-25-2011, 08:37 PM
it did to me but i also had a bad tps sensor (code 7) and it would run like ****...!!!
Old 03-25-2011, 08:39 PM
N'viouzEF9's Avatar
i had that code b4 then i change my throttle body n it went away ill see if i can get another fpr
Old 03-25-2011, 10:24 PM
N'viouzEF9's Avatar
i also meant the exhaust fumes smell like gas really strong
Old 03-27-2011, 01:40 PM
Laserjock's Avatar
It is possible the harness you bought as a replacement have crossed wires if all you did was switch to the new one and the car ran fine before. It could be injector wire signals were crossed.
I would try another harness. Most jumper harness are not color coded so unless you know what you are doing, it would be a headache to trace the wires to the pinouts.
How bad is the broken wire in the old harness btw. It might be an easy fix. Post a pic
UPYOURZ
04-17-2008 02:29 PM
almostboostedgsr
03-26-2007 10:57 AM
eg6turb0
12
01-15-2005 08:02 PM
eg6turb0
01-10-2005 11:44 AM
crxtreme27
07-13-2002 10:45 AM
Quick Reply: car is running really ruff smells like gas to HELP!
