need help
Old 06-14-2011, 06:19 PM
jerzeyjoe's Avatar
Default need help
ok i have a 88 si crx that has a d15b with a z6 head car is turboed i just put a headgasket on and now it wont start.it turns over the fuil pump dosnt kick on and its not getting sprak.everything is pluged in the way it was
Old 06-15-2011, 03:25 AM
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
Default Re: need help
Ok...??? Do some of the basic checks - if you did a head gasket you should be able to check your grounds, triple check connections, is your battery in the car correct, all fuses good, ect... Essentially what you did shouldn't cause your fuel pump to not prime. So get that fixed and go from there.
Old 06-15-2011, 12:49 PM
jerzeyjoe's Avatar
did all them 3times still nothing its nuts
Old 06-15-2011, 01:07 PM
Keyboard Humorist
4drEF's Avatar
You changed the headgasket and now it won't spark and fuel pump won't kick in.
I'm assuming you mean that the fuel pump doesn't even prime when you turn the key to ON and not even try to start it.
This really really really sounds like your ground lugs at the thermostat housing are disconnected.
Old 06-15-2011, 01:18 PM
jerzeyjoe's Avatar
ill look at it and the car turns over just wont start
Old 06-17-2011, 04:18 PM
jerzeyjoe's Avatar
the grounds are good just put a new main relay and still wont start
DA9b0y303
29
08-21-2013 03:51 PM
teg racer 877
03-05-2009 05:40 PM
allmotor2.1
11-21-2007 05:45 AM
Soccerking3000
12
12-21-2005 06:10 PM
Quick Reply: need help
