Cant find a rebuilt si steering rack
Old 05-10-2014, 03:50 AM
hondatuner020's Avatar
Default Cant find a rebuilt si steering rack
So ive replaced all the inner and outer tie rods, as well as the rack end bushing. I no longer have any play when shaking or tugging on the inner tie rods, but when i rapidly shake the steering wheel back and forth i still hear clunking sounds coming from the rack.
Any thoughts?
the rack did appear to be extremely dry when i inspected it, i feel it may be worn
If i get a replacement rack, should i go new or remanufactured?
http://www.carsteering.com/addtocart...80-70071.html#
also how do i know if im getting an si rack, every new rack claims they fit both, which we know the si is different than the hf/dx.
If anyone knows of who sells rebuilt or new si racks that would be great.
Old 05-10-2014, 08:13 AM
Tyson's Avatar
Default Re: Cant find a rebuilt si steering rack
You didn't adjust the pinion did you....
Old 05-10-2014, 04:49 PM
I forget to add that i did as well with the tool from Honda. Tight then backed off a 1/3 - 1/2 turn
Old 05-10-2014, 08:21 PM
Tyson's Avatar
back it off less.
Old 05-10-2014, 08:32 PM
longest project ever
lostforawhile's Avatar
Location: on the south side of dixie, 1986 Accord Hatch
what is the difference between racks? also if the pump isnt running a clunk is normal when you do that, assuming this is power steering
Old 05-11-2014, 06:20 AM
brizzle86's Avatar
I would check the steering column u joint on the inside of the car. These wear out and will cause a clunk that seems to be coming from the rack but is just noise transfer. Its right at were the column meets the rack and is very easy to change out.
Old 05-11-2014, 12:23 PM
Tyson's Avatar
I agree and the u joint itself can be worn.
Old 05-11-2014, 05:15 PM
i re-tightened the rack adjustment and the noise changed slightly but was still very noticeable. the Ujoint appears to be in good condition, it dosnt flex or make noise. if i put my ear to the floor can tell its coming from the opposite side.
Im just going to get a new rack at this point.
Does anyone have any recommendations?
Old 05-11-2014, 05:39 PM
I had really good luck with the one from Nappa, they usually come in two grades, get the better one
Old 05-11-2014, 07:13 PM
I didnt see one online at napa....
also this is what it sounds like after adjusting it again.
CLICK
& Turn you speakers up
GeoMetry
05-11-2014 12:24 PM
twr32
01-03-2009 11:18 AM
griz50cal
04-11-2008 07:28 AM
MulletManRockStar
01-16-2005 01:28 PM
smokey2.0
02-16-2003 06:43 PM
Quick Reply: Cant find a rebuilt si steering rack
