Old 03-25-2015, 12:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Lighting
Print Wikipost
Brake lights don't turn off
Old 09-10-2007, 03:56 PM
Hond@'s Avatar
Default Brake lights don't turn off
hey guys, my brake lights don't turn off even when the car is off. Do you know what cause this? I know it's a shortage somewhere but where should i look? Please help me!!!!!!!!!! Thanks
Old 09-10-2007, 03:57 PM
CRX Toad's Avatar
Default Re: Brake lights don't turn off (Hond@)
You need to adjust it down by your brake pedal.
Old 09-10-2007, 04:00 PM
Hond@'s Avatar
Default Re: Brake lights don't turn off (CRX Toad)
how would i do that??
Old 09-10-2007, 04:03 PM
Torque Junkie
Trakhor's Avatar
the brake light switch is on a bracket such that when you depress the pedal it releases the switch, this action completes the circuit to turn on the lights.
there is also a plastic plug in the bracket that sometimes falls out and the switch is not depressed when the brake pedal is all the way up.
Old 09-10-2007, 04:06 PM
Hond@'s Avatar
Default Re: Brake lights don't turn off (Trakhor)
soo is there a screw or something i should adjust? sorry im not at my car right now.. Thanks for the help
Old 09-10-2007, 04:54 PM
Tyson's Avatar
i have no idea why CRX TOAD is giving you BAD advice. forget what he's telling you.
you need to look for blue plastic bits on the floor under your pedals. i guarantee youll find em like this
its #13.
youll see a hole in the brake pedal now. fill that hole with another bumper from the junkyard or a makeshift bolt that fits in its place. or this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "shorte" &raquo;</TD></TR><TR><TD CLASS="quote">What I use now:
Like $5 from AutoZone, 15 pack, instead of $2something each from Honda.</TD></TR></TABLE>
Old 09-10-2007, 05:03 PM
Torque Junkie
Trakhor's Avatar
Default Re: Brake lights don't turn off (Tyson)
Is there not an adjustment on the brake light switch? If so I'm sure that's what the Toad was refering to
Old 09-10-2007, 05:05 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trakhor &raquo;</TD></TR><TR><TD CLASS="quote">Is there not an adjustment on the brake light switch? If so I'm sure that's what the Toad was refering to</TD></TR></TABLE>
thats not the problem.
Old 09-10-2007, 05:12 PM
rbwdriven's Avatar
that is not the problem it is the little bumper that they are talking about I have had to replace them on my rex and civic. Look at the brake pedal go upwards you will find the switch. The detent part of the switch is going through a hole in the brake pedal where the little rubber bumper sits. Replace rubber bumper and you are good to go.
Old 09-10-2007, 05:15 PM
88DXCRX's Avatar
Location: I told you to wait in the truck in Texas, United States
The switch is adjustable,
But if it was working before,
Chances are the rubber bumper has crumbled like Tyson described..
Before:
After:
Old 09-10-2007, 08:30 PM
Brian Hinson's Avatar
I use a ten mil. bolt an nut. works great, never have to worry about it coming apart again
Old 09-10-2007, 10:53 PM
RCautoworks's Avatar
Default Re: Brake lights don't turn off (Brian Hinson)
Also to add because I have seen this happen, the switch itself gets stuck. So make sure its not stuck .
Old 09-11-2007, 04:57 AM
fireant's Avatar
Default Re: Brake lights don't turn off (RCautoworks)
ANNND There is one on the clutch for 89+ cars, so one day when your car doesnt start, look in the floorboard first!
Old 09-11-2007, 07:52 AM
Scotland:EF3's Avatar
the part is like 3 bux at the honda dealership, i just did mine but your new one will be white in color not the dark blue
Old 09-11-2007, 08:01 AM
89efDUSTY's Avatar
High % of chance it is the clip... I replaced mine with Electrical tape @ a washer
Old 09-11-2007, 03:49 PM
Hond@'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">i have no idea why CRX TOAD is giving you BAD advice. forget what he's telling you.
its #13.
holy **** bro.. i was wondering what those blue pieces on my carpet were from!! thanks man
Old 09-11-2007, 06:01 PM
Tyson's Avatar
added to the FAQ under Suspension and Brake.
Old 09-11-2007, 06:58 PM
Street Racer X's Avatar
sucks when that happens. I duct taped a quarter to my pedal where the plastic stopper fell out on my 240sx years ago and it stayed in place for a couple years. Ghetto but it worked.
Old 09-11-2007, 11:14 PM
Tyson's Avatar
Default Re: Brake lights don't turn off (JohnnieChimpo)
happened to my 88 last year.
happened to my friends 91 last week.
Old 09-12-2007, 12:11 AM
EF_RICE's Avatar
just replaced one last year in auto tech class... and just replaced one in a buddys crx 2 days ago...
Old 09-12-2007, 05:09 AM
I CRX I's Avatar
replaced mine about 4 months ago. officially mark, year number 16-19 for ef's is years of the mysterious "crayon" looking plastic apearing on everybody's carpet. for those who have the fortune of still having one in tach, replace now before your battery drains unsuspectedly.
Old 09-12-2007, 01:23 PM
88DXCRX's Avatar
Very good Johnnie..
A 5/16" standard size will work also..
Some folks have "slammed" me for recommending a bolt
saying the impact of the hard object might damage the switch..
If you autocross or drive aggressively,
A softer material might be a better choice,
but the bolt suits me fine as I release the brakes gently and
don't ever "pop" my foot off of the pedal.
Old 09-30-2007, 07:20 PM
talkJDM's Avatar
This just happened on my 97 EK Hatch ... I quickly diagnosed the problem as this, but I thought this was for only old chassis models (EF, DA, etc), but apperantly the EK Chassis uses the same thing still - why didnt honda change it? I dunno ... Anyways I was right, this was the problem ... I fixed it with a 10mm Bolt and Nut
Modified by talkJDM at 10:54 AM 10/1/2007
Old 10-19-2007, 08:23 AM
draperj09's Avatar
Default Re: (talkJDM)
happened to me a couple months ago
there was a screw that busted on mine
so i put a bigger better badder one in place
Old 10-19-2007, 09:37 AM
New User
WWDTrackRacer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">happened to my 88 last year.
Happened to my 88 on the racetrack a year ago. Everyone following me thought I was a madman on the circuit....
Quick Reply: Brake lights don't turn off
