Best budget suspension for 88 CRX Si...
Old 09-18-2001, 05:32 PM
88 CRX SiR's Avatar
Default Best budget suspension for 88 CRX Si...
The current suspension on my newly acquired 88 CRX SiR sux! Jamex springs/shocks at all four corners. The ride is very rough and looks to be 2" lower than stock. I know Koni Sports are awesome with Ground Control coilovers, but that's expensive. I won't be competing in AutoX with this car, I'll leave that for my AE86!
For now, I'm thinking of replacing the shocks with KYB AGX adjustables (already have the fronts from my DA, only need rears) & keep the springs until I can afford new springs like H&R Sports. (lower springrate)
Any recommended setup would be appreciated.
Old 09-18-2001, 05:50 PM
jaje's Avatar
Default Re: Best budget suspension for 88 CRX Si... (91TegRS)
kyb agx and ground controls are a decent cheap alternative
i'd do polyurethane bushings (get black ones...don't squeak) too for even better response
Old 09-19-2001, 05:58 AM
keithv's Avatar
If the drop on the Jamex springs is 2", be careful using KYB AGX shocks. KYB recommends springs <50% stiffer than stock and a ride height drop of no more than 1.25".
Old 09-19-2001, 08:03 AM
88 CRX SiR's Avatar
Default Re: Best budget suspension for 88 CRX Si... (jaje)
Looks like I can't use KYB AGX in rear because on their site, they list only for 89-91 CRX. Plus the rear LCA for the 88 is like the ITR....
The other thing I have to consider is that I'm converting from rear drums to rotors off a 90-93 Integra which will include LCA's...ugh! So where does that leave me? hmm...too much to think about...
Old 09-19-2001, 08:12 AM
88 CRX SiR's Avatar
Default Re: Best budget suspension for 88 CRX Si... (breaka_1_9)
Yeah, I know. That's why I'm considering a full change of shocks/springs too. KYB AGX may be good, but they're only available for 89-91. My 88 has rear LCA's like ITR's so I'm out of luck. Plus I'm converting from rear drums to discs off a DA (90-93 Integra) so I'll be using those LCA's.
Old 09-19-2001, 08:51 AM
keithv's Avatar
Can't you swap the DA LCAs for the ones in your 88 CRX Si? I think most LCAs are bolt up, just the LCAs have different designs...
Not totally sure, but its probably worth a shot.
regal1975
10
04-15-2007 09:23 AM
trianglegreg
22
12-14-2005 09:08 AM
trianglegreg
12-13-2005 06:14 PM
CRX_F1
Suspension & Brakes
07-05-2005 04:46 PM
Quick Reply: Best budget suspension for 88 CRX Si...
