bad coolant temp sensor
Old 02-10-2008, 11:57 AM
slammedz6ef's Avatar
Default bad coolant temp sensor
i have a ls swap converted to obd1 and i was seeing how can i tell if my coolant temp sensor is bad.......
when i start my car in the morning it runs pig rich and idels at 1k so i have to rev it to 3.5k to warm it up and i have to do that for about 10-15mins then the cel comes on and it runs perfect!!!!!
could that be a bad coolant temp sensor?
Old 02-10-2008, 12:15 PM
zcmotor's Avatar
well i think 1k its where it should be at. You might just want to replace the sensor. or it could also be the tps sensor. which both of them are not that expensive. if you getting both of the codes just go and fix it before the problems gets worst.
Old 02-10-2008, 12:27 PM
MONSTERZC's Avatar
Default Re: bad coolant temp sensor (slammedz6ef)
What is the code you are getting. It sounds like you have a cold starting issue. It could be the coolant temp sensor. If the sensor is bad the cel would be on all the time and run rich at all times. What is your gas mileage like. what are you using for ems are you using. Are you sure your wiring is right.
Old 02-10-2008, 12:38 PM
Default Re: bad coolant temp sensor (MONSTERZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MONSTERZC &raquo;</TD></TR><TR><TD CLASS="quote">What is the code you are getting. It sounds like you have a cold starting issue. It could be the coolant temp sensor. If the sensor is bad the cel would be on all the time and run rich at all times. What is your gas mileage like. what are you using for ems are you using. Are you sure your wiring is right.
the cel comes on after it warms up, im getting about 24mpg, yea the wiring is good
Old 02-10-2008, 12:40 PM
MONSTERZC's Avatar
do you know how to check the code. if you want help we need the code.
Old 02-10-2008, 12:42 PM
how do i check it? i dont have a blinking light or anything like how my b16 did
Old 02-10-2008, 12:51 PM
MONSTERZC's Avatar
if i remember right there is a light blue plug under glove box or in the pass side kick panel use a paper clip or something and plug it into the two spots and if you did it right turn the key on but dont start it and count the cel on the dash.
Old 02-10-2008, 01:16 PM
ill try it real fast
Old 02-10-2008, 03:25 PM
Crx Jimmy's Avatar
check the code . on the obd1 conversion harness it should have 2 wires that you need to touch together or run them to a switch to check the codes
Old 02-10-2008, 03:36 PM
Default Re: bad coolant temp sensor (Crx Jimmy)
its code 6
Old 02-13-2008, 06:15 PM
MONSTERZC's Avatar
ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor Check the wiring if its ok then replace the ect.
Alexpbnj
11-17-2010 05:18 PM
EKstacy
12-31-2007 02:37 AM
turbociv
01-02-2006 04:20 PM
rc90hatch
12-19-2005 04:01 AM
nickzed20
01-25-2005 03:44 PM
Quick Reply: bad coolant temp sensor
