90 civic lx dpfi - PCV question
i just took off my intake manifold to clean everything up, changed the hoses, new clamps and i put everything back and the pcv and the hose attached to it, ripped so can i drive with out it? whats the name of what its attached to on the top of the manifold are they both pcv's just one is platic and 1 is metal? is there a plug if so where can i get it and whats the size?
DO IT ON ALL FOURS
Re: 90 civic lx dpfi - PCV question
What are you talking about on the top of the manifold? The vacuum port? Also - don't run the car with out at least blocking the hoses off. You will have a massive vacuum leak and drivability will suffer. Why don't you just replace the hose? You can buy bulk hose for around $1 a foot...
i was told the catch can can be open but the top needs to be closed with a nut or something but i also read that in a way its not good because the pressure and would cause gaskets to go out sooner than usual so im thinking just getting a hose from the junk yard and just spray both pcv's with carb cleaner and put everything back but if i wanted to put the nut what size is it and whats the pros n cons about it thanks
I would like to thank you guys for your advice and ill probably go get the hose at junk yard and pcv. Can I ask another question about the radiator?
DO IT ON ALL FOURS
Why would you ask if you can ask a question when you wasted the space with a question asking permission for the question wanting to be asked?
It's your thread, rather than clogging the forum with pointless threads, ask away in the one you already started...
ok so i was having to top off fluid every few days or long drives.
theres no leaks on the floor, i had some extra time so i dis-assembled the intake manifold and cleaned it out with carb cleaner.
also checked all the hoses, 2 where replaced and one of those where re-routed to the top of dpfi manifold coming from water pipe.
the adapter wich those hoses connect to had a small hole from rust so thats why i re-routed. fluid doesnt seem to go down as much as before but i had a friend tell me to bring it by the shop he can pressure test it for me so i was wondering whats reasonable for a tip $5 or $10 and has any one used prestone radiator flush? i need to flush my system after the check up n fill with new radiator fluid for the protection of my car.
search on how to do those, it's pretty easy. if the car has ever over-heated, the thermostat is probably bad.
Semper_WiFi
06-22-2009 12:01 PM
Nextelbuddy
03-26-2004 05:08 PM
citanest
01-14-2002 10:26 PM
