89 crx bouncing idle help please
Old 03-09-2011, 01:10 PM
slob20ef's Avatar
Default 89 crx bouncing idle help please
I swapped a d15b into my 89 crx dx, converted to obd1. Im having problems with the car bouncing or surging idle, from 1200-1600 rpm. I took the FITV apart, cleaned and tighten. I also cleaned IACV, then replaced with another. Bleed coolant system a million times now. I plug the hole inside the TB and no difference, i unhook the IACV and still no difference, now it will idle at 800 steady rpm fine, you give it a very little throttle and it starts surging, all vacuum lines are fine, checked with carb and choke cleaner, same with Tb and Im gaskets. I hardwired IACV to ecu, A9, blk/blu wire, and grounded the yell/blk. Ive fixed several cars with this problem before but this has got me. Seems like the IACV wiring is not right, but its not hard wiring a 2 wire plug.. any ideas?
honcrf150
01-01-2013 04:03 PM
HBK
23
11-17-2010 04:59 PM
crxfreak1117
09-08-2007 07:05 PM
QWKPHKR
08-11-2002 11:35 AM
Quick Reply: 89 crx bouncing idle help please
