zc in to 92 si
Re: zc in to 92 si (altech_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by altech_si »</TD></TR><TR><TD CLASS="quote">can anyone tell me how to do the swap from a 92 si to a zc engine . </TD></TR></TABLE>
what is the point of that swap? isn't the stock z6 stronger than the zc?
Re: zc in to 92 si (1.6i-16zc)
that depends if it is a sohc or dohc,Dohc is a goot engine for turbo but you need fab a IM for it and in general its hard to get aftermarket parts for the dohc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by altech_si »</TD></TR><TR><TD CLASS="quote">1 because the engine is free
2 because i herd it make's a good turbo engine
correct me if im wrong... but this is going to be a street setup right?
the higher compression d16z6 will spool a turbo faster than a dohc zc will. i would rather have the z6...
It will be a direct bolt in if u get a 92+ Dohc Zc motor. I have one in my car right now (94 motor) and i have absolutely no problems (i have a 93 cx). u have the si tranny and ecu so u will be running just fine if u decide to do this swap. Also the zc is rated at 130-135hp where the si is 125 i beleive! Its a great motor for the price!
Solbros Owns Me
Re: zc in to 92 si (Chris y0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! »</TD></TR><TR><TD CLASS="quote">
the higher compression d16z6 will spool a turbo faster than a dohc zc will. i would rather have the z6...</TD></TR></TABLE>
the DOHC ZC has lower than 9.2:1 compression! wow
Re: zc in to 92 si (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">
the DOHC ZC has lower than 9.2:1 compression! wow </TD></TR></TABLE>
wow thanks for the INFO!!!! nice turbo motor !
Solbros Owns Me
Re: zc in to 92 si (civicHBphtride)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicHBphtride »</TD></TR><TR><TD CLASS="quote">
wow thanks for the INFO!!!! nice turbo motor ! </TD></TR></TABLE>
NO NO NO....that was an excited comment/question.
I doubt it's lower than the Z6. But 9.2:1 is already plenty low for boost. I wouldn't even build an engine for boost with less than 9.5:1 anyways.
Does anyone know the compression of DOHC ZC?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">the DOHC ZC has lower than 9.2:1 compression! wow </TD></TR></TABLE>
my bad... i got them mixed up.
the sohc zc has 9.1, the dohc has 9.6
