wtf donut gasket
Old 12-03-2015, 10:41 AM
710dabber's Avatar
Default wtf donut gasket
i have a 99 honda civic ex with a b18c itr swap in it it has a tri y apexi header trash yeah i know it has like a 2 to 2.5 in outlet and my exhaust is 60mm im having a hard time finding out what donut gasket to use to connect from the header to the exhaust someone please help me out
Old 12-03-2015, 11:21 AM
yippee-ki-yay
eHMxhACk's Avatar
Default Re: wtf donut gasket
I'm not 100%, but I think an S2000 gasket would work.
eH.
Old 12-03-2015, 12:33 PM
710dabber's Avatar
Your the man bro what year s2000?
eH.
Old 12-03-2015, 12:40 PM
yippee-ki-yay
eHMxhACk's Avatar
Look at part number 18229-PCX-003.
eH.
Old 12-03-2015, 07:29 PM
710dabber's Avatar
I looked up the part number but its one of those flex gaskets any that are the same size but not flex ?
eH.
Old 12-03-2015, 08:25 PM
Hysterically Calm
TomCat39's Avatar
Specifically, what junction/flange are you mating? The bottom of the header to the catalytic converter/test pipe? (This is a flex gasket)
Or are you trying to find the gasket between the tri y's of the two piece header? (This is typically a 2 hole flat gasket)
Or the gasket on the back side of the catalytic converter/test pipe to your long pipe? (This is typically one large hole triangular shaped flat gasket)
Flex gasket is a doughnut gasket that the catalytic converter can "flex" on with the spring bolts and still seal.
Old 12-03-2015, 08:26 PM
I never narc'd on nobody!
NotARaCist's Avatar
This is the P# he gave you. That's a doughnut gasket. Also called a crush gasket. It's what you need.
Old 12-03-2015, 08:31 PM
Hysterically Calm
TomCat39's Avatar
It's also called a flex gasket by many sources, Honda included.
But I also explained why the terminology is used.
27
18229-SR0-003
Gasket, EX. Flexible
1 $15.75 $10.87 Submit
28
18229-SH3-X30
Gasket, EX. Flexible (50mm-64mm)
1 $25.00 $17.25 Submit
Pulled for my car but the same location just different sized gasket.
Honda Part No.: 18229-PCX-003
Fast Delivery
Dedicated Service
Guaranteed Genuine
Your Price: $23.63
Retail Price:$34.25
You Save:$10.62
Qty:
Add OEM Honda Gasket to Cart
Old 12-03-2015, 09:13 PM
710dabber's Avatar
It is a 1 piece header apexi 4:2:1 and from the header to test pipe i just wanna be sure that's the size before i order from honda you have been a lot of help man I'll buy it tomorrow and keep you updated on how it goes
Old 12-04-2015, 09:51 AM
Hysterically Calm
TomCat39's Avatar
I think the S2000 flex gasket might be a bit big.
Did you say your outside diameter of the header was 2.0"?
If so the flex gasket on the S2000 is for 2.5" and doesn't fit.
I am thinking your header output size is the same as my two piece one and the S2000 flex gasket was much too large.
What I found fit the 2" pipe was the Walker 31357 flex gasket.
uberEFtuner
04-24-2019 08:38 AM
crazyboy
10-17-2011 09:17 AM
ImportsCRX
02-28-2004 10:48 PM
Bklyn TSi
12-23-2002 05:24 AM
Quick Reply: wtf donut gasket
