2000 Honda Civic White smoke engine
Old 06-24-2014, 05:19 AM
Crystal N's Avatar
Default 2000 Honda Civic White smoke engine
HELP!!!
I have a 2000 Honda Civic, took the car out for a short drive(20 mins or so) and it started having white smoke and the temp gauge was almost in red. So I turned the car off and let it cool. Then turned the car back on, I last about 5 mins before it got bad again. I put some coolant in and tried to go again. That did not help, I made it about 50 feet.
it is White smoke, coming from around the engine. It has no smell that I noticed.
Any Ideas?
Old 06-24-2014, 05:28 AM
94CivicSi's Avatar
Default Re: 2000 Honda Civic White smoke engine
Sounds like leaking headgasket. What does the oil look like on the dipstick? Milky?
Old 06-24-2014, 05:30 AM
Crystal N's Avatar
No still looks like normal. it was a little low, normal tho
Old 06-24-2014, 05:49 AM
I like the tuna here
DumpdEJ6's Avatar
White smoke and overheating is a blown head gasket. Can't think of anything else it could be.
Old 06-24-2014, 05:53 AM
The Grumpiest
grumblemarc's Avatar
Maybe a busted hose? Usually don't the headgasket issues push smoke out of the exhaust?
Old 06-24-2014, 09:56 AM
Bleakened's Avatar
This happened to me and I had a hose break in a spot that was very difficult to find. Fill up the radiator to the top and see if you can hear/spot any leaks. Look for dripping under the car as you fill up. I had a hose break from the bottom and I couldn't see the leak from above.
Old 06-24-2014, 06:18 PM
demas16's Avatar
Could be the lower rad hose. i had this happen to me too
Old 06-25-2014, 05:58 AM
DumpdEJ6's Avatar
I either read OP's post wrong or he edited it. Yeah, white steam around the engine area is most likely a busted hose somewhere or maybe the radiator cap losing pressure.
boostedjdmdc2
10-22-2006 08:16 PM
ReggieGrip
02-21-2006 06:12 PM
EtherEG93
09-17-2005 08:18 PM
CRX_Control
11-10-2004 09:29 PM
Layziebtnh055
10
04-16-2004 02:22 PM
Quick Reply: 2000 Honda Civic White smoke engine
