White smoke when cold start and oil in spark plugs
Old 06-10-2012, 07:49 PM
ZXiPoZ's Avatar
Default White smoke when cold start and oil in spark plugs
Hi there,
My mom 2000 civic lx 4cyl automatic 4 door, when its on cold start, I see kinda white-blue smoke come out from the exhaust, and it smell bad . The smoke disappear within 10s. Today I changed the spark plugs and found the oil are in base ring. Therefore, what is the problem w it, is that blown headgasket??? Thank for all
Old 06-10-2012, 09:55 PM
EK9
Dc4LsTeG's Avatar
Default Re: White smoke when cold start and oil in spark plugs
When you write can you type correctly. Do a leakdown test
Old 06-11-2012, 02:14 AM
92lxsleeper's Avatar
its fine. you have leaky valve seals. replace those and you'll be golden.
as for the smoke. the blue is from the valve seals dripping oil into the cylinder overnight.
and the white is from the heat/condensation. go outside when its cold and exhale through your mouth. white smoke, same principle as the car.
Old 06-11-2012, 02:19 AM
ribal_gh's Avatar
*2
Old 06-11-2012, 02:59 AM
vtec-8400rpm's Avatar
correct
dont forget to buy the correct valve stem seals - exhaust and intake are different. installing some cheaper seals that dont differentiate between the ex/intake will result in the same issue a couple miles down the road.
Old 06-11-2012, 07:02 AM
motegicivic's Avatar
He also said oil on the plugs.......oil of the electrode you mean?
Either your spark plug tube seals are shot.
Old 06-11-2012, 02:27 PM
ZXiPoZ's Avatar
Thank guys for your advice. I will check them all and replace soon. Im not a Eng speaker, so I try best to write it down
Emmanlumb
03-22-2016 10:59 AM
Peteypablo17
02-17-2013 04:46 AM
lilpaintballer02
22
03-05-2010 08:13 AM
Broken Gearbox
08-08-2003 09:00 AM
snoop_bealybob
10-05-2002 10:16 AM
Quick Reply: White smoke when cold start and oil in spark plugs
