What are these wires/plugs for?
#26
Re: What are these wires/plugs for?
thats a good one, i just looked at the spare dx dash harness that i have and it doesnt have either one of those plugs on it. I have a blue male plug that goes to the fuse box, but u have a female end. it must be on the main harness inside the car that they are connecting to.
#27
It's not a dash harness. It's part of the harness with the fuel pump going towards the under dash fuse box.
#28
So it's under the carpet on the left side of car? If so, I will pull my carpet up and take pics for you tomorrow.
From what you are describing it's the main harness, which the FSM only shows one 14 pin connector on the main harness going to the rear of the car on the left side.
Are they both 14 pin connectors? just different colors?
#29
Yeah, left side under carpet. Might be a little further up tho.
Thanks for your help. I'll be home around 8 or so, and on MY fsm, there's more than one Plug, I think. Lol. I'll post more pics when I get off after work.
#31
Okay, here are the picturessss.
As you can see, the fuel pump harness is there, leading upwards towards the dash is the wires I'm having problems with. It goes under the dash, I know that for sure.
WHAT THE HELL DO THEY PLUG INTO AND WHAT ARE THEY FOR?
And here's a picture of the gray plug where 1 of the 3 plugs that come from the fuel pump/rear of car go to.
I just need to know where the other 2 go! EFFF!
#33
looks like the power mirror plug. those 3 plugs look like they are for the center of your dash. radio subharness, hazards, and the last i'm not sure.
#34
I couldn't find those plugs on my sol, but I wasn't able to pull my carpet all the way up. I'm sorry I couldn't find them man.
#37
OK, If I am following you correctly
The gray female plug is shown in my first pic, below cruise module.
The green male plug goes into the back upper portion of the fuse box, shown in my second picture
The blue female plug attaches to the tab on the upper portion of the fusebox, should be in my last pic.
Let me know if this helps or not.
#38
Whoa.... so the green plug I'm looking at plugs into the fuse box?
In the last picture, I see that the blue plug is sitting there, but is anything plugged into it?
Hey, man. Thanks for taking pics for me it's helping me out. I just wish I effing remembered, so I didn't have to go through this. LOL.
I appreciate your help!
I just need to go back in my garage and try this **** out again. I swear I tried putting the green plug in the fuse box already, but it wouldn't go.
I'll try again and let ya know after school tomorrow.
#41
^No disrespect or anything. But, if you read the original post thoroughly, what you just posted will sound retarded.
#42
It looks like, on mine anyways, that all the green plugs, plug into your fusebox.
The blue plug has a female mate that goes up into the dash harness.
What you are seeing in the pic is the dash side of the harness, the dash side plugs or attaches on the front side of the fusebox, while the main harness goes/attaches from the back of the fuse box.
Hope that helps.
Tim
Hope that helps.
Tim
#44
Hope that helps.
Tim
Hope that helps.
Tim
I'll update you guys. Thanks for all the help so far.
#45
the green plug won't plug into the fuse box.
and i still couldn't find anything that the plugs into the blue plug either.
#47
Mine has a male and female blue plug, that plug into each other, you might not even have the second blue plug, since mine is a Si and your's a Dx.
On mine all green plugs either plugged into the front or back of the underdash fusebox.
If you can wait a day or two, I have a spare dash harness, main harness, engine harness with all fuse boxes being delivered. Once I get it, I will take better pics of the harnesses laid out on concrete, with all connectors, fusebox locations, etc.
#48
Oh look, I can change this
"A" for effort, guys! But not quite there yet, I don't think.
Here's what you need to know:
First off, the GREEN plug plugs into the BACK of the fuse box. GREEN plugs ALWAYS plug into the fuse box. From the Helms, it is connector C556 which plugs into C927 on the fuse box. Note that it even says "To rear wire harness". (NB: You don't have the smaller C555 connector because you don't have an Si or EX which has power mirrors/windows/door locks. These functions plug in there.)
I know you say you've looked, but all I can say without trying to sound snarky is that you haven't tried hard enough. That's where it goes, no question about it.
The BLUE connector mounts on TOP of the fuse box, and connects to the dashboard wiring harness. There's a BLUE female one that fits into it.
Here's where it mounts, on the left side in this photo taken from my Cruise Control retrofit DIY (link in sig):
jasoncanseeoh, I'm helping you even though you were a bit of a jerk to me in another thread, though you did apologize (kinda). I hope this helps you out and you can continue on your project! Cheers.
#49
DeSchlong, thanks a whole lot for the help.
PROBLEM SOLVED!
BUT, one last problem. I have a service manual and ****, but it's hard to comprehend. What the hell plugs into the bottom part of the fuse box? Because from what I know it's a rear harness plug. Although, I already have the three of them plugged in.... what the eff?
BTW, deschlong.......I don't remember what thread it was, but I was just in a bad mood maybe? lol
PROBLEM SOLVED!
