weird engine squeak
Old 04-28-2009, 02:36 PM
dtarvin's Avatar
Default weird engine squeak
just checkin for ideas...
i have a weird squeak coming from the engine bay, sounds like it's on the back side or around the mount. i've since replaced the rear mount, and the squeak is still there. when i throttle the squeak pulses faster then slows down as i release throttle.
when i press on the clutch at all, the squeak goes away. it's driving me crazy.
Old 04-28-2009, 02:38 PM
RunninEg6's Avatar
Default Re: weird engine squeak
belt tension?
Old 05-01-2009, 03:37 PM
dtarvin's Avatar
i don't think it's a belt because the squeak/chirp goes away completely when i press the clutch in at all.
maybe a bearing or something in the transmission? any way to really check without pulling the transmission off?
Old 05-01-2009, 03:52 PM
Former User's Avatar
Probably a bad input shaft bearing in the transmission.
Old 05-01-2009, 03:59 PM
Randomluck's Avatar
Throw out bearing is bad.
Old 05-01-2009, 04:48 PM
hondavtecsi1's Avatar
can you post a video of it with sound check if it does it when u get on the throttle a little
Old 05-01-2009, 05:07 PM
EK9r!der's Avatar
it sounds like the throw out bearing might be going bad.
Old 05-01-2009, 05:54 PM
A bad throw out bearing would produce noise when the clutch pedal is pushed.
Old 05-02-2009, 04:21 AM
Randomluck's Avatar
Nope but thanks for playing. It squeaks when it's free spinning with minimal load. When the clutch is depressed it put the max load on the bushing. The pressure changes what you hear from a high pitched squeal to a low grade rumble that easily gets lost in the engine noise. It gets worse as the bearing gets ready to give its final spin and then you may or may not hear it.
Old 05-02-2009, 06:14 AM
...It squeaks when it's free spinning with minimal load. When the clutch is depressed it put the max load on the bushing. The pressure changes what you hear from a high pitched squeal to a low grade rumble that easily gets lost in the engine noise. It gets worse as the bearing gets ready to give its final spin and then you may or may not hear it.
This explanation seems plausible, though it would represent a rare situation. Your explanation also generally conflicts with the majority of forum threads that describe how to diagnose clutch and transmission noises. This thread is just one of many examples.
peterphn
Transmission & Drivetrain
10-26-2012 11:56 AM
Sorcin
05-18-2010 09:24 PM
spens 91 Ef
29
03-08-2009 08:15 AM
pelotudo
06-20-2002 02:11 PM
BoM
03-14-2002 08:20 PM
Quick Reply: weird engine squeak
