URGENT! 98 civic slipping in drive
longest project ever
Location: on the south side of dixie, 1986 Accord Hatch
OK this is the issue, I hope it's an easy fix, 98 civic lx, sometimes the transmission will shift fine, sometimes it will be fine, then it appears to be stuck between gears, if I shut the car off, and let it sit a few seconds, i can start it up and the transmission will shift again, it's also been shifting slowly, I really need to fix this, this is my only running car, and I'm laid off, plus my wife is sick, I'm not sure how old the fluid is, I also need the location of the drain, and how much is the refill. I can take a manual tranny apart blindfolded, but i can't stand auto's. I had a bad cv axle, it didn't come apart or anything, I thought this might be the source, also does anyone know about this?
that's from a service bulletin, is this an external solenoid? or is it a disassemble transmission deal?
I'm going to get a code reader from the loan a tool thing tomorrow, and see if i have a transmission code, I already have a check engine code from the secondary O2 sensor, so I may have additional codes, if the tranny is shot, I'm hoping someone has an auto one they will sell me cheap, I know they aren't popular, I'm perfectly capable of removing and installing one, if i can find one and get it here, we really need this car running badly.
Automatic transmission: Automatic transmission may shift harshly due to contaminated linear shift solenoid. Fix includes repeated fluid changes plus installation of a new solenoid. (1996-2000)
Re: URGENT! 98 civic slipping in drive
well no luck, i changed the fluid and nothing, it shifted easier, i was shifting it fronmdrive into reverse and driving back and forth on this small concrete area, and it was fine, then all of the sudden it won't go into gear. the sfifter will, but the transmission won't. does someone know if it has a filter screen? are there band adjustments? the fluid that came out looked terrible, but didn't smell burned, and it still had a red color, it might have been in there for 200000 miles for all I know
ok it's the linear shift control solonoid valve, there is no way I have the money to replace that, I'm looking for someone who had a bad transmission, and there are probably a lot of them out there, to find one of those valves, i will take a picture of it, easy to remove couple of bolts at the front of the transmission, right above the shift valves.
anyway the solenoid works outside of the car, since it acts up when the transmission warms up, and the solenoid is engaged for long periods of time, i'll hook it up to 12 volts for a while and let the solenoid warm up, i may also warm some tranny fluid and put the valve section in it and let it sit, it could be closing for a shift then sticking closed. the metal will expand when warm and it may stick then if something is worn.
everything i've read says it won't trip a code, the computer calls for the valve to function a certain way, but there is no feedback from the valve. I haven't found one yet, since it ,malfunctions when the car warms up, I'm going to do some hot checks on the valve to try to see if it fails while reopening, it works cold, but so does the car. i only have problems after warm up. On the positive side, I didn't find any clutch material in the screens for the regular shift valves.
I would think a bad valve would trip a code. Nonetheless, it's worth testing. What CEL codes are thrown?
What type of ATF did you use to refill the transmission? It's important to use Honda or Honda-recommended ATF. In addition, you should drain and refill three times total because 1/3 of the ATF remains in the transmission after a drain.
my_zero
04-14-2016 12:29 PM
Afg10Keg
16
07-26-2015 04:31 PM
mdick85
Transmission & Drivetrain
01-31-2012 04:15 AM
