What kind of SPRAY to use to coat/protect coilover sleeves
Old 03-23-2004, 05:23 PM
ApexiChild's Avatar
Default What kind of SPRAY to use to coat/protect coilover sleeves
Well I'm getting Teins SS...
I wanted to know what works best in protecting the coils & sleeves & adjustable ****.
I would like to find a simple spray but if all else fails I can always slap on the old fashion lub/grease to protect it from dirt, corrosion, salt, air and SNOW... (MN)
I should be able to clean them once every month in the summer and maybe once every 3months in the winter.
THanks in advance fella & gals
Old 03-24-2004, 03:52 AM
Charlie Moua's Avatar
Default Re: What kind of SPRAY to use to coat/protect coilover sleeves (ApexiChild)
bump guys.... I'm sure many guys want to know this as well
Old 03-24-2004, 05:02 AM
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=788568</TD></TR></TABLE>
good link, but can you apply that to the SLEEVE threads?
and still be able to adjust them freely?.....
Old 03-24-2004, 03:00 PM
ApexiChild's Avatar
anyone....
i'm in upper dulth a few hours away from freaken canada guys... help me protect my investment...
I think i might just have to wrap the sleeves with duck tape
Old 03-24-2004, 03:12 PM
bloopie's Avatar
Default Re: (Dimi)
I usually just coated my coilovers with some wd40 every month or so after i sprayed them down and wiped off any excess gunk...
Worked fine for me.
Old 03-24-2004, 03:16 PM
jaxle's Avatar
wd40 is a solvent with lubricant added to it, it doesnt stay there very long. just put clean grease on there and whenever u adjust it clean it off so you dont get grit jammed in the threads.
Old 03-24-2004, 03:26 PM
dpw41285's Avatar
Default Re: (jaxle)
sil glyde or shinitsu (sp) grease
Old 03-24-2004, 03:49 PM
93hatched_projekt's Avatar
Default Re: (dpw41285)
Actually tein ss have a nice stanless steel sleeve that holds up nicely. I've had mine a little over a year and till this day ,they still look brand new. Just clean them with brake cleaner to get all the loose dirt and grit off and lube it with some wd40...Works good for me and I'm constantly adjusting the coilovers.
Old 04-07-2004, 03:51 AM
Default Re: (93hatched_projekt)
thanks!
Old 04-07-2004, 04:16 AM
B18C4-T's Avatar
Default Re: (Charlie Moua)
I have K&W coilovers, they came with a teflon spray that is designed specifically for this. I think you can order the spray off their website. Larry
Old 04-07-2004, 04:23 AM
OG triple OG
ATS*Mark's Avatar
Default Re: (B18C4-T)
my flex's are starting to get rust spots on the threaded parts of the adjustment ***** , how can i clean that rust off ???
Old 04-07-2004, 05:05 AM
menkio's Avatar
Default Re: (Hella_JDM)
nice teins and the kid can't clean rust.
Old 04-07-2004, 05:08 AM
OG triple OG
ATS*Mark's Avatar
Default Re: (DewMota)
who the **** ever said i couldnt , i asked what to clean it with.
Old 04-07-2004, 05:09 AM
scratchy's Avatar
well if you just pressure wash them when you wash your car you will be fine
Old 04-07-2004, 06:06 AM
Jdmbsixteen's Avatar
Default Re: What kind of SPRAY to use to coat/protect coilover sleeves (scratchy)
Don't use wd40 buy some silicone spray wd40 is not meant to lubricate.
Old 04-07-2004, 08:06 AM
sil
sil's Avatar
well, I've been using this product for every single car and i find it works great: http://www.krown.com they also have an aersol can with their product, I think it goes for ~$10CDN. You'd have to contact them to see if they can send it to you, as far as I know krown is not available anywhere in the US.
hi-Powered
04-03-2005 06:23 AM
1.8
Welding / Fabrication
03-04-2005 03:38 PM
EGPHANTOM
10-13-2004 11:36 PM
chrish
05-15-2004 09:48 PM
Ya@inlinePRO
08-18-2003 08:54 AM
Quick Reply: What kind of SPRAY to use to coat/protect coilover sleeves
