Trouble removing Fuel Line from Fuel Filter...
Old 10-09-2005, 09:06 AM
moonpieboy's Avatar
Default Trouble removing Fuel Line from Fuel Filter...
I'm trying to replace my fuel filter. The only thing preventing me from doing this is removing the fuel line from the fuel filter. I have a fixed wrench and I've been trying to turn it clock-wise to detach. I know normally you turn counter clock-wise to remove. But since the fuel line is attached from the bottom, I believe you would do the reverse. Thou...considering I haven't been able to budge. I've also tried using a wrench to hold the fuel filter and another to turn the fuel line. But it still didn't budge.
So - any suggestions would be welcomed. And please let me know which way I should be turning it to remove the fuel line.
This image shows how the fuel filter and fuel line connect. Item #49 is a washer that is between the two.
Thanks!
-moonpieboy
Old 10-09-2005, 09:26 AM
my_slow_civic's Avatar
Default Re: Trouble removing Fuel Line from Fuel Filter... (moonpieboy)
It still goes counter clockwise, if you were to look at it from under the filter. You will need to have a wrench, holding the filter from turning. Then put a little muscle behind it, and crank it loose.
Old 10-09-2005, 09:29 AM
moonpieboy's Avatar
Default Re: Trouble removing Fuel Line from Fuel Filter... (my_slow_civic)
Thanks for the reply. I kinda figured that I was turning it the wrong way.
I'll give it another try.
-moonpieboy
Old 10-09-2005, 09:30 AM
senpai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic &raquo;</TD></TR><TR><TD CLASS="quote">It still goes counter clockwise, if you were to look at it from under the filter. You will need to have a wrench, holding the filter from turning. </TD></TR></TABLE>
He meant that since we remove the filter from ABOVE that he would turn the wrench clockwise when looking from ABOVE.
Turn CLOCKWISE when looking from above
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moonpieboy &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the reply. I kinda figured that I was turning it the wrong way.
-moonpieboy</TD></TR></TABLE>
you'll expletive it up turning counterclockwise looking from above
Old 10-09-2005, 09:57 AM
Default Re: Trouble removing Fuel Line from Fuel Filter... (senpai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by senpai &raquo;</TD></TR><TR><TD CLASS="quote">
you'll expletive it up turning counterclockwise looking from above</TD></TR></TABLE>
Uhh, yeah, thats why I put in there if you were to look at it from <U>under</U> the filter.
94DOHCDELSOL
02-04-2005 11:00 AM
asmallsol
02-25-2004 05:47 AM
get wet racing
01-06-2003 06:16 AM
AK94GSR
08-07-2002 08:02 PM
Quick Reply: Trouble removing Fuel Line from Fuel Filter...
