Transmission casing cracked?
Old 07-18-2009, 02:25 PM
calvin924597's Avatar
Default Transmission casing cracked?
So today I noticed some oil on my driveway... jacked up the car and it appears that the transmission casing is cracked. I just got the car 6 days ago... and this definitely wasn't disclosed when we purchased the car. Is it a difficult repair? And since I just got the car 6 days ago and have driven it less that 200 miles, is there some way to get the seller to pay for the repair? I took a pic of the crack... it looks terrible
calvin924597 is offline
Old 07-18-2009, 02:54 PM
iamthefollower's Avatar
Default Re: Transmission casing cracked?
it was probably a sold as is deal, so you probably can't get the seller to pay, you could try some quick steele on it and see if it'll work. I know a guy here has done that before and it worked, but if it doesn't work then you might have to get the casing swapped or just put another transmission in.
iamthefollower is offline
Old 07-18-2009, 02:56 PM
I'll probably have to try the quick steele then... how much do you think a new housing is gonna cost? I'm not sure I want to do the labor myself.. this is my first car
Old 07-18-2009, 03:03 PM
H-T White Ops
Frozen E's Avatar
You're probably better off just buying a new tranny. I'm guessing this is off a SOHC something or another. If so, trannies are a dime a dozen. Really cheap all things considered.
Frozen E is offline
well you might be able to find a casing, but then again they are kinda hard to find. If you can get any B series hydro tranny casing then it will work. but when I checked on one it was $50, but I had to check around the net. If you do the quick steele, then drain all the fluid out, clean where the crack is, put the quick steele on and then make sure it hardens before putting any fluid back in the transmission. if you make sure it gets heated and hardened and make sure you get the whole crack covered then it should work for you.
Old 07-18-2009, 03:06 PM
this is true, if it is a single cam then you can find a whole tranny for cheap, I was thinking it was a B series for some reason lol.. I was thinking bout my tranny.. yeah if you need to then you can get a SOHC tranny for cheap and put it in.
Old 07-18-2009, 03:09 PM
How much do you think a SOHC tranny would be?
EDIT: Including labor... I dont have an engine hoist or anything
Old 07-18-2009, 03:11 PM
zXeX's Avatar
If u quick steel it, it has a better chance of sticking it if you use steel wool or a wire wheel on a drill to clean the area around the crack.
zXeX is offline
Old 07-18-2009, 03:18 PM
would using that stuff keep the integrity of the housing? or is it gonna be weakened...
Old 07-18-2009, 03:19 PM
H-T White Ops
Frozen E's Avatar
Automatic or manual transmission?
Check craigslist for the MSP area. There's a guy parting out an auto SOHC civic right now.
http://minneapolis.craigslist.org/pts/1274873408.html
DOHC tranny
http://minneapolis.craigslist.org/pts/1273598449.html
Another EX
http://minneapolis.craigslist.org/pts/1271701550.html
As far as price to do the work....you're on your own on that one. Start calling shops in your area. I can swap a tranny without having to putt the motor in about 4 hours. Shops tend to take their sweet time so count on at least 5 hours. $60 and hour, you're looking at about $300 for labor. Give or take a hundred.
Frozen E is offline
Old 07-18-2009, 03:22 PM
it's going to harden up pretty good but it isn't going to be the same as the transmission first was. I mean you could use it and if it ends up not working you could buy you a tranny. If you were here I could get you a tranny and put it in for you for $350 but looks like you are way off from Georgia.
Old 07-18-2009, 03:33 PM
Well I guess I'll have to try the quick steele then... im gonna give that guy parting out the civic a call... see how much he wants for the tranny. Whats a good deal for a auto tranny? I dont want to be ripped off.
What I'm worried about is the crack might be bigger than I think... If you look at the picture it seems like it goes around and under that end plate... which would make this whole thing a ton harder.
Old 07-18-2009, 03:36 PM
true, it would be better just to get another tranny and put it in.. try and see how much it will cost for you to have your tranny swapped up there.
Old 07-18-2009, 03:42 PM
All the shops around here charge $100 an hour... It's ridiculous :/ And they'll probably go by the labor time guide in the books... so I'm probably looking at $400 in labor alone.
Old 07-18-2009, 03:51 PM
do you know any "shadetree mechanics" up there?? if you know anybody like that then they might give you a better price on it.
Old 07-18-2009, 04:31 PM
Yeah, I don't know... I might just try to replace it myself. How long do you think it would take me to replace the whole thing? Its an automatic transmission. I have all the tools I think, except for the transmission hoist.
Old 07-18-2009, 05:06 PM
if you can get someone to help you then you could have it done in around 5 hrs, but you have to get in there and do the job and get it done. Have you ever done any work on a car before?
Old 07-18-2009, 05:32 PM
NACvicSi's Avatar
Unless it was stated to have a warranty a used car purchase is as is. I would clean it up real good (go ahead and drain tranny fluid), scuff it up with some steel wool, and lay some JB weld over the crack. Replace with some Honda MTF and should be good to go for awhile. Just keep a eye out for a cheap replacement tranny to buy when you find a good deal.
NACvicSi is offline
Old 07-18-2009, 05:38 PM
blacc_ej1's Avatar
JB Weld?
blacc_ej1 is offline
Old 07-18-2009, 05:44 PM
NACvicSi's Avatar
Available at any auto store or Wal-Mart
NACvicSi is offline
Old 07-18-2009, 06:25 PM
lol jb weld comes in handy lol..
Old 07-18-2009, 07:27 PM
92lxsleeper's Avatar
you don't need an engine hoist for the transmission lol. my si transmission weighs in at 66lbs.
92lxsleeper is offline
Old 07-18-2009, 07:35 PM
Lol I doubt I could lift the transmission above my head and bolt it in at the same time... plus its an auto transmission so it probably weighs more
Old 07-18-2009, 07:37 PM
well once you get it lined up, there are dowel pins it sits on, so the transmission will hold itself to the block while you bolt it. but if you gotta pull the trans out, its a perfect time for a 5 speed swap. i just finished mine, along with a d15b6 TO d16z6 swap. new flywheel and a new stage 2 clutch kit
Old 07-18-2009, 08:02 PM
hmm... a manual would be nice. how much would it be to do a complete swap?
Quick Reply: Transmission casing cracked?
