Torque Spec Request for Rear Spindle Nut/Torx 50 Bolts
Old 10-03-2009, 03:18 PM
teamm_AP1's Avatar
Default Torque Spec Request for Rear Spindle Nut/Torx 50 Bolts
Hey you guys, I need some help for torque specs the rear 24mm Spindle Nut and the Torque spec for the Torx 50 bolts.
I have looked through alldata, haynes manual, and honda-tech and found nothing.
It would be a great if you guys can help me out.
Old 10-03-2009, 04:26 PM
Danthemagicbum's Avatar
Default Re: Torque Spec Request for Rear Spindle Nut/Torx 50 Bolts
call honda dealership?
Old 10-03-2009, 07:57 PM
teamm_AP1's Avatar
They wouldnt help.
Old 10-03-2009, 08:07 PM
but i did bump for you, and it was the only other thing i could think of
Old 10-03-2009, 09:25 PM
teamm_AP1's Avatar
^^ Thank you..
So After searching for a while, I found that the rear spindle bolt is either 134 or 136lbs.
Not luck on the torx 50 bolts.
Also, I found a diagram on the trailing arm assembly and the diagram doesnt clearly list the 4 torx bolts. weird.
teamm_AP1
Suspension & Brakes
10-05-2009 05:27 PM
ntensehonda
Honda S2000
01-07-2009 11:56 AM
NZDelsoldude
12-23-2006 02:50 PM
02Civic*Si*
04-04-2004 10:48 AM
Quick Reply: Torque Spec Request for Rear Spindle Nut/Torx 50 Bolts
