torque on crankshaft pulley
Old 09-03-2009, 09:47 AM
go'in crazy's Avatar
Default torque on crankshaft pulley
After a bit of a nightmare trying to remove the crankshaft pulley bolt,while changing the timing belt, I'm puzzled as to why it has a torque spec. of 134ft/lb ?On a pulley with splines and a key, what is the chance of anything loosening? My experience with V8 engines has been that the torsional damper to crankshaft bolt usually gets between 60/90 ft/lb. Any thoughts or opinions?
Old 09-03-2009, 10:20 AM
Former User's Avatar
Default Re: torque on crankshaft pulley
I have read multiple threads on Civic forums where the crankshaft pulley bolt comes loose, leading to destruction of the crankshaft. Best to torque to spec.
Old 09-03-2009, 10:22 AM
1992Si's Avatar
x2 what he said
Old 09-03-2009, 11:17 AM
I shall follow your advice and do it right. On the same subject, timing belt, my Haynes manual gives me a diagram for setting the camshaft, which says to line up the horizontal marks on the sprocket with the surface of the cylinder head (D15B7). The diagram shows those marks offset slightly forward,toward the rad. If I use a steel square set on the cylinder head, and line up the marks eqally,would I be correct?
Old 09-03-2009, 12:00 PM
I'm not Rick!
rick_rabies's Avatar
make sure the UP on the cam is up and the 2 lines on the cam gear are horizontal and even with the surface of the head...
California98Civ
08-09-2014 10:14 PM
Jaz760
17
04-09-2009 09:25 PM
jdmCivic925
07-14-2006 09:03 AM
LeonardDB
11-21-2005 05:28 AM
216.226.142.95:27016
03-06-2005 09:10 AM
Quick Reply: torque on crankshaft pulley
