Timing light ?
Old 07-29-2008, 07:04 AM
hondachris1994's Avatar
Default Timing light ?
when I point my timing light on the crank pulley, there is 3 lines. The line all the way to the left is where the mark on the timing belt cover is pointing at...is that correct?
Old 07-29-2008, 07:33 AM
any 1 have a link for this?
Old 07-29-2008, 08:03 AM
superfast666's Avatar
Default Re: (hondachris1994)
there should be 3 lines really close together the correct timing would be the middle mark it should be red
Old 07-29-2008, 08:07 AM
Default Re: (superfast666)
I shot my timing and its on the left line, but I also have motor work done, so is this okay or does it need to b in the middle line?
Old 07-29-2008, 08:51 AM
bump for some info
Old 07-29-2008, 09:16 AM
jime64871's Avatar
depends what kind of motor work did you have?
more info would help...
Old 07-29-2008, 09:28 AM
thesmogman's Avatar
Default Re: (jime64871)
You should line up the middle mark of the three. The middle mark is your spec. and the outer two are a reference to the alotted 2 degrees you can be off. So the outer marks are + or - 2 degrees from your spec.
The white mark is the TDC mark and if you have an advance-able timing light you can dial up the spec degree on the light and it should show you the white TDC mark. This is a way to double check your setting.
Old 07-29-2008, 11:48 AM
jime64871's Avatar
Default Re: (thesmogman)
best advice you'll get, right there ^
regarding timing..
honda4fun
06-11-2009 04:09 PM
JDMtype Eg6
09-03-2008 05:14 AM
kholmes
05-24-2004 07:01 AM
slowd16z6
03-13-2004 02:20 PM
Quick Reply: Timing light ?
