which throttle body gasket do i use on my y7 to y8 throttle body change?
Old 06-02-2012, 10:38 AM
ATLien6's Avatar
Icon2 which throttle body gasket do i use on my y7 to y8 throttle body change?
Doing a y8 mini me with a y8 intake manifold
Switched y8 throttle body with y7 throttle body and y8 rotor
Ordered a head gasket kit that fits y7, y8 and the gaskets for both y8 and y7 are different than the 2 gaskets that came in my kit....
So which throttle body gasket do I use on a y8 manifold with a y7 throttle body?
Old 06-02-2012, 10:41 AM
The Grumpiest
grumblemarc's Avatar
Default Re: which throttle body gasket do i use on my y7 to y8 throttle body change?
Why did you not use the Y8 throttle body?
Old 06-02-2012, 01:18 PM
ATLien6's Avatar
Read on FAQ for y7 y8 mini mes that I'm supposed to swap throttle body's and rotor , use the y7 throttle body with a y8 rotor, can I just swap the throttle rotor from the y7 to the y8 and use the y8 throttle body?
Old 06-02-2012, 01:23 PM
Arthas's Avatar
You are correct, use the Y7 throttle body with the IACV attached but swap in the rotor from the Y8 throttle body so it spins in the correct direction.
Im not sure you have to change gaskets, when I did my Y7 to Y8 conversion, I reused the original gasket with no leaks or CEL's.
The Grumpiest
I went through those. I don't see where the OP said anything about swapping throttle bodies.
I used the D16y8 head, intake manifold, throttle body, fuel rail, and injectors
Is this so you don't have to do any wiring for the IACV?
Old 06-02-2012, 01:30 PM
ATLien6's Avatar
I had Hondapartshero tell me this in a previous thread I created, but I just need to know if I can reuse the gasket, hence me buying a new one, since I'm using the y7 throttle body should I use the y7 gasket?
Old 06-02-2012, 01:53 PM
The Grumpiest
eltexmexalex
12-29-2016 06:00 AM
ek-tuner
04-04-2008 10:16 AM
slow_SIvic
03-24-2007 08:29 AM
trooper0641
07-04-2004 10:50 PM
Quick Reply: which throttle body gasket do i use on my y7 to y8 throttle body change?
