taping noise, sounds bad
Old 03-06-2005, 05:39 PM
drowzysleeper's Avatar
Default taping noise, sounds bad
my d16y8 just started making a tapping noise, i adjusted the valves and it still made the noise. im pretty sure that it is coming from the valvetrain. or somwhere on the top of the motor. its not a knocking sound, but its a loud tap. it does it between 2500 and 3500 rpms, it started when i was getting on the highway was wondering if it might have something to do with the vtec. i was thinking that the hydralic things that kick in the vtec are stuck and it is making the valves rattle. only other thing was when i took off the 1st spark plug wire it didnt make the sound. im hoping it isnt a piston or rod help please.
Old 03-06-2005, 05:47 PM
SOHC4life 96's Avatar
Default Re: taping noise, sounds bad (drowzysleeper)
At first I thought it was a spun rod bearing but you said its coming from the head. I really doubt it has anything to do with the VTEC lobs. Bump for an answer.
Old 03-06-2005, 06:05 PM
Farmer Brown's Avatar
Default Re: taping noise, sounds bad (SOHC4life 96)
The injectors are usually pretty loud. Other then that I have no idea.
Rods and pistons usually just go, when they go bad.
Old 03-06-2005, 06:09 PM
tonis56's Avatar
Default Re: taping noise, sounds bad (Djaric)
did you adjust the valves completely cold??
Old 03-06-2005, 06:53 PM
so you dont think that it is the lobes? what about the spark plug wire why does the sound stop when i unplug that one and not the rest? if its the pistons how much more would high compression ones cost over new stock ones if anyone knows>?
Old 03-06-2005, 07:04 PM
imptricer's Avatar
sorry your fucked
i have a d16y8 in pieces right now i spun a bearing
it had the same symptoms as what yours did and i found metal shavings in my oil pan which means my block is fucked
if your going to by 4 new rods and pistions i would just go by a b series or something for twice the price which mods done to it
reply
good luck though
Old 03-06-2005, 10:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drowzysleeper &raquo;</TD></TR><TR><TD CLASS="quote">so you dont think that it is the lobes? what about the spark plug wire why does the sound stop when i unplug that one and not the rest? if its the pistons how much more would high compression ones cost over new stock ones if anyone knows&gt;?</TD></TR></TABLE>
YOu need to do some serrious research before you just start wanting high compression pistons...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imptricer &raquo;</TD></TR><TR><TD CLASS="quote">sorry your fucked
reply
good luck though
Spody02
11
01-08-2009 07:02 PM
mikeunreal2
04-21-2006 10:15 PM
worditsmenick
09-16-2005 06:24 PM
gassinit
07-27-2004 08:53 PM
Quick Reply: taping noise, sounds bad
