tail lights wont work?
its weird my tail ligths dont work. Only when i press the brakes they come on?... When i turn on the lighs only the headlights work? Can anyone help me? PLease thank you!- 92-95 honda civic
Re: tail lights wont work? (EGmikeH22)
mine are doing the same thing.. ill clear this up a little bit.. when night sets in and time for headlights i turn mine on and my headlights turn on.. look at my guage.. and no lights.. and also no running lights in the rear.. every time i put a new fuse in it pops it in 2 seconds.. if that.. any ideas on how to fix? i think that if i pulled out the brake lights and running lights and put a new fuse in with them out and turn them on it would either pop the fuse or not.. if it didnt then i know the problem lays in the lights.. if it does then theres a wire going to ground right? and i drive a 94 del sol
Re: tail lights wont work? (jdmone)
OMg... My gauge cluster doesnt work either>>>> anyone know what fuse im looking for cuz i dont have a fuse box cover thingy... So i dont know which one i test >>>> thank you!
Re: tail lights wont work? (apc123eg)
you should have a spare top row first one 10 amper if you have been workin under your dash you should take it back apart and make sure you didnot messup one of the wires good luck
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmone »</TD></TR><TR><TD CLASS="quote">OMg... My gauge cluster doesnt work either>>>> anyone know what fuse im looking for cuz i dont have a fuse box cover thingy... So i dont know which one i test >>>> thank you!</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1966666
Re: tail lights wont work? (MR Rodgers)
It sound you have a wiring problem other than that have no other suggestions to tell you same thing happened in my 95 four door.
Re: tail lights wont work? (IW92)
ok to everyone having this problem i was too.. then i relised that it has to be the bulb.. brake lights work and dont blow the fuse.. and its on the same ground.. but different fuse.. pulled the bulbs. and put in two new ones and a new 10 amp fuse and BOOM!! they work... CHECK YOUR BULBS!
k i have the same problem
but they work when i turn on my car and they stay on
one i press my brakes they go off and wont come on unless i shut off my car and re turn on i just put new bulbs and i doutb it that is the fuse but ima check all my fuses when i have time and if they are not blown what else can it be maybe the bulb socket are burn
long story how this happ to me lmao
SlowWhiteEvo
02-18-2004 08:23 AM
