Stripped oil pan drain threads D16Y8
Old 09-18-2011, 07:07 PM
strategy400's Avatar
Default Stripped oil pan drain threads D16Y8
Its the D16Y8. Just bought a 98 EX coupe and the oil drain plug is dripping and feels like if I snug it anymore it will strip completely. It has what looks like an aluminium pan. Any repair possible without replacing the pan? Can it be tapped without introducing metal debris? Would that liquid thread repair stuff work?
Old 09-18-2011, 07:10 PM
Former User's Avatar
Default Re: Stripped oil pan drain threads D16Y8
Are you sure you just don't need a new drain bolt crush washer? The drain bolt should only need 33 lb-ft of torque.
Old 09-18-2011, 09:24 PM
Solomon1468's Avatar
^^ definitely check the crush washer. If you do/did strip the threads, just spend the $60 on a new pan. Pretty easy and straightforward replacement and will be a permanent fix as opposed to anything you can get at your auto parts store.
Old 09-19-2011, 06:55 PM
Pan is aluminium or something, ~$200 from Honda. I'm pretty sure the threads are ready to let go. I'll probably end up pulling the pan and installing a timesert. Ugh..
At least I'll have steel threads after.
Old 09-19-2011, 06:58 PM
joeshmo's Avatar
~20 dollars from a junkyard. One could always take off the pan to tap if you're worried about metal debris.
Old 09-19-2011, 09:34 PM
NotAJDMFanBoy's Avatar
PM me if you need a replacement pan. I got a junk D16Y8 in my garage. If a steel pan off a D15B7 would fit, I got one of them too. People are saying $20, so I'd say $20 plus my cost to ship.
Old 09-20-2011, 12:42 AM
apexi_rsx's Avatar
d15b7 pan will not fit ! it has a different oil pump hole alignment for the pan. it would have to be a oil pan from a 96-00 civic with a d16 motor. y8 has an aluminum pan and the y7 had a steel pan.
Old 09-26-2011, 06:09 PM
I'll likely remove the pan next oil change after I try a new plug with a torque wrench and new washer.
2000civ
16
09-13-2012 07:15 PM
SpeedoKing
01-14-2010 05:03 AM
CScivic22
Northeast (Sales)
05-19-2009 07:17 PM
gasha1
01-09-2009 05:55 AM
Quick Reply: Stripped oil pan drain threads D16Y8
