Stripped Oil Drain Plug Help
long story short,
lowered car, scraped oil pan molded shavings to plug, bolt is completely stipped to a circle.... how can i take it out, ....
already 5k over due for my oil change, really need help
Need to drill it out, or a die/tap kit maybe?
If your that clueless about the situation, i would go to a oil-change shop somewhere, and let them look at it. If i were you, id start looking for a used oilpan.
Are you aware that craftsmen makes stripped bolt removers? Doesnt even matter if its a ciricle, the way they work is that the teeth dig-in, id try that before doing anything else.
the problem is that the pans metal scrapes molded to the ring of the plug
If I was to get an replacement oil pan would a eg d15 pan work?
I got a replacement plug from an DA b18 integra 17mm but will it fit perfectly?
Thanks in advance
Thanks in advance
