Strange noise from front end-wheel bearing? easy answer im sure
Old 09-30-2011, 12:04 PM
Mr.Chow's Avatar
Default Strange noise from front end-wheel bearing? easy answer im sure
So it's been awhile since I've owned a civic, but I picked up a 96 LX last night and had a questions on something that's been driving me nuts.
So with the wheel straight (the wheel shakes a little over 70 mph and gets worse going 80 and above) I hear like a humming vibrating noise that when turning left at higher speeds (55 and above) seems to have a pulsing effect. When turning right the noise goes away completely, in fact if you just ever so slightly move the wheel to the right the noise will go away as well.
When I jacked up the car the driver's side wheel had very slight play in it and the lug nuts were pretty damn hot, on the passenger side the lugs were a little hotter still, but no real play in the wheel.
I'm thinking this is symptoms of a wheel bearing going bad, am I right? What else could it be? Other than that the car drives nice and straight.
On a side note, does the LX come standard with ABS?
Old 09-30-2011, 12:20 PM
jimsiggy's Avatar
Default Re: Strange noise from front end-wheel bearing? easy answer im sure
CV joint will cause noise too, and some vibration felt on the floor. Hot lugs could be from the brakes; regular braking or dragging too. my 2cents
Old 09-30-2011, 12:35 PM
Mr.Chow's Avatar
good point on the brakes. thanks.
Old 09-30-2011, 02:42 PM
Mr.Chow's Avatar
TTT...wheel bearing?
Old 10-01-2011, 12:47 AM
ej2Tigre's Avatar
I would say CV joint. From my personal experience, wheel bearings make a metal-on-metal dragging/scraping sound (or clunking) constantly not intermittently. When you spin the wheel, while in the air, do you hear anything similar to that? and are you lowered by any chance?
Old 10-01-2011, 02:36 AM
D3vin's Avatar
I would double check re-torquing your wheels. Your brakes could be warped and your wheels might need re-balancing. (Hence the shaking after 70).
Old 10-03-2011, 07:54 AM
Mr.Chow's Avatar
brakes are not warped and the wheels are balanced and torqued correctly. I'm going to do the wheel bearing tonight and hopefully that will take care of it.
avio
04-11-2010 12:40 PM
David12
10
11-15-2009 01:35 PM
Mr.Luder
10-16-2007 03:54 PM
Blastek
10-18-2004 08:34 AM
Suprdave
12
06-27-2002 07:58 AM
Quick Reply: Strange noise from front end-wheel bearing? easy answer im sure
