SRS reset; inspection problems 'NOT READY'
Old 03-12-2009, 12:54 PM
dafuzzbudd's Avatar
Default SRS reset; inspection problems 'NOT READY'
So at somepoint i started the car with my seat out giving me an srs light, i left in on for probably 3-4k miles because it didn't bother me a whole lot. Inspection time comes around so i reset the light with paperclip trip, light goes away, drive around for maybe 30 miles, fail for 'NOTREADY'. I'm thinking I just need to drive around more. A trip to the mountains, 350 miles, and a week later i try again. I still fail for 'NOT READY'. WTH
I asked the inspection guy if they plugged my car into the computer, and he said something like 'it's not a plug'. I tried to explain how I thought it worked 'you guys hook up a computer to the plug under my dash' and he was being odd by just repeting general information and acting like he didn't unserstand me.
Do I need to drive 500+ miles? Or maybe i messed something up when i wired up my alarm, is there a fuse to check? My friend has an obdII reader/resetter I'm gonnig to try to test with.
Old 03-12-2009, 12:56 PM
ekb16's Avatar
Default Re: SRS reset; inspection problems 'NOT READY'
im guessin ur car is obd2? did u by any chance ask him WHAT was it that was NOT READY
Old 03-12-2009, 03:45 PM
dafuzzbudd's Avatar
yes, obdII. i was given a printout, i think it was 'obd system' 'saftey systems' and another safety something. ill grab the sheet out of my car and post a bit later
Old 03-14-2009, 07:42 AM
dafuzzbudd's Avatar
eh, list is home, where im not. There are about three 'NOT READY' and the reset 'NOT USED'
Old 03-16-2009, 04:53 PM
dafuzzbudd's Avatar
catalytic converters: NOT READY
Oxygen Sensors: NOT READY
Evaporative System: NOT READY
Overall Readiness Result: FAIL
Those are the 4 things highlighted, the others say 'Ready' or 'Not used'.
Old 03-17-2009, 08:44 AM
dafuzzbudd's Avatar
up
Old 03-17-2009, 09:03 AM
marecco's Avatar
im assuming you unhooked your battery to clear the airbag light or something like that? that clears everything out of your system and the monitors for those systems that say not ready need to be reset. typically you have to drive some miles like over 50 for all the monitors to reset.
Old 03-17-2009, 12:48 PM
dafuzzbudd's Avatar
the srs reset is the paperclip trick: unplug srs connector from under dash fuse, loop the circuit, start ignition and wait for blinks, unplug paperclip light will come back on, plug back in.
i was reading on Nissan forums that some cars require certain # of trips. Ill try it again this Thurs
If I fail again im going to try and reset the ecu (neg battery terminal)
Old 03-18-2009, 12:58 PM
ekb16's Avatar
these are called your Readiness Monitors..there are certain driving conditions (trips) that u gotta to do to set these..try doing this, it should set the 02 and cat if they are working properly
1. start he car up cold and let it idle until warmed up (fan comes on 1x)
2. drive the car at a steady speed of 25-60mph for at least 6miles
3. that should set the 02 and cat monitor by now, if not then there might be something wrong
Old 04-16-2009, 09:41 PM
dafuzzbudd's Avatar
just to complete this thread..
turns out my radio/ecu mem fuse blew under the hood. fixed the issue and am now inspected and legal.
was expired since july. thx H-T
Old 04-16-2009, 11:11 PM
Davus's Avatar
I had the exact same thing happen last year. I was going to suggest this if you hadn't found the solution. Sucks too, wasted a lot of time (but not money) on the problem.
But I have my own OBD2 code reader now with readiness monitors!
mitchchizo22
03-25-2009 09:41 AM
Curt941
06-27-2004 05:25 AM
GRAVEDIGGER
10-10-2002 12:25 AM
Blue teg
11-09-2001 11:58 PM
Phat Corolla
07-17-2001 04:06 PM
Quick Reply: SRS reset; inspection problems 'NOT READY'
