some insight on how to prevent a lip from getting stolen
well, i finnaly stopped futzing around ang picked up a lip (which i love i might add)
so my question is, how can i keep her safe, like anyone use special screws? they steal **** down to the dam air caps in ny so i wanna take no chances.. i know if they want it they'll grab it but anything to slow em down
JB Weld that bitch on there. They'll have to take the whole bumper if they want the lip. That should at least set your alarm off, and if you dont have an alram I'm going to come to your house and slap you.
lol i have an alarm, and cant drop it THAT low too many potholls and possums lol
jb weld.. i like that idea tho
i got stuff a bit more potent than that **** too
you wanna guarantee that it won't get stolen? Don't put it on! lol jk you can use everybody's ideas and mix and match the bolts along with your stuff that is "a bit more potent" anything to slow the thieves down. good luck with it.
Seagull Management
Re: some insight on how to prevent a lip from getting stolen (k0rupt_ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k0rupt_ed »</TD></TR><TR><TD CLASS="quote">well, i finnaly stopped futzing around ang picked up a lip (which i love i might add)
so my question is, how can i keep her safe, like anyone use special screws? they steal **** down to the dam air caps in ny so i wanna take no chances.. i know if they want it they'll grab it but anything to slow em down</TD></TR></TABLE>
If your really serious about this buy some security torx machine screws, whatever size you happen to need and then go buy a driver to install them, they're like normal torx only they have a little pin in the center.
Re: some insight on how to prevent a lip from getting stolen (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 »</TD></TR><TR><TD CLASS="quote">
If your really serious about this buy some security torx machine screws, whatever size you happen to need and then go buy a driver to install them, they're like normal torx only they have a little pin in the center.</TD></TR></TABLE>
Those are called tamper proof torx
Blue Point has a tamper proof torx bit set if you go that route.
Here is a place to start.
http://www.securitycosmos.com/...at=52
They also have bolts that the heads break off at a certain torque so those are another option. No way those are coming off easy.
Seagull Management
Re: (k0rupt_ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k0rupt_ed »</TD></TR><TR><TD CLASS="quote">know where i can buy em?</TD></TR></TABLE>
No, but it you try you whoever sells nuts/bolts/screws in your area they can get them or at least point you in the right direction.
H-T White Ops
Re: (Nbboy7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nbboy7 »</TD></TR><TR><TD CLASS="quote">the screws i gave you are hard to get off unless some one gona carry like a 6mm socket on them. But you can try nuts and bolts</TD></TR></TABLE>
You mean a 6mm socket, like one that might come in a socket set that a thief might carry around?
The tamper proof torx screws sound like a good idea. I've seen a few sites that sell security hardware.
http://www.tamperproof.com/ind...ducts
http://www.apexfasteners.com/?...w9crQ
http://www.brycefastener.com/?...3sQrg
http://material-handling.globa...screw
http://lianteng.en.alibaba.com/
to prevent from your lip getting stolen you use a alan screw to tighten your lip on cause what thieve walks around with with a alan keys they usally walk arounds with flat heads and screw drivers most people use normal screws that easily can be taken off with a screw driver or a flat head like I said again, tools that thieves carry on them.
Im with turbo-2nr, rivet it on! And the tamperproof torx is not a bad idea either. If someone wants it THAT bad they will get it...its just a matter of time. All you can really do is slow them down and hope they get caught in the act.
Hide in a tree with a shotgun. After a while, theives will just stay away...or there won't be any left. Either way, it works.
I'm feeling violent today. Deuschbags at work are pissing me off.
Re: (batallic)
in my bathroom at school they have a weird screw that holds the barriers to the wall.
think of a flat head that will only tighten. the other side is sloped up so it will just spin.
use alot of screws/bolts, and then JB weld it also.
at least this will **** the thieves off with spending so much time taking off the bolts, only to have it not come off
Re: (beastsohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic_1337 »</TD></TR><TR><TD CLASS="quote">in my bathroom at school they have a weird screw that holds the barriers to the wall.
Haha yeah, [freak] it, take your bumper off, flip it upsidedown and just run epoxy or JB down it, and get an electric drill and have some fun haha.
Re: (SeanZ0r)
It would be so cool if you could have your car electrified at night. So if someone touches it, it shocks them.
Anyway I like the idea of stripping the screws once you put the lip on. Shouldn't be too bad because you could always buy the tool so you can remove stripped screws.
