Slow/weak cranking after clutch change. What's the culprit?
Did a clutch change a few days ago and ever since then my car has been cranking really weak and takes quite a few cranks to start up now. Before the clutch change it was cranking really string and well. I am certain it is not the battery because why would it all of a suddent go weak after a clutch change when it was running just fine before?
Re: Slow/weak cranking after clutch change. What's the culprit? (EK k kay)
Check the ground on the thermostat housing and check the wires on the starter. It sounds like the starter isn't getting the proper voltage...
Re: Slow/weak cranking after clutch change. What's the culprit? (EX-T)
Just checked the grounds on the starter to see if they were loose as well as the tranny ground. Still cranking a lot weaker than it used to. I will try checking the thermostat ground tomorrow.
Well I checked the grounds, pulled the starter and bolted it back in. 2 out of 6 times it cranked normally. Would an improper flywheel resurface cause this? Or is my starter going out?
Mr. Badwrench
sounds like a voltage issue. an improper finnish on the surface would at most cause chatter on engagement.
Re: Slow/weak cranking after clutch change. What's the culprit? (boostedcivicsir)
Ahh. I guess it's time to pick up one of those voltage/current readers.
